I don't see what the disadvantage is of building the universal binary. Actually, the Darwin universal 32/64 universal build is more flexible than either the 32 or 64 builds alone. You can build the core EPICS libraries using the universal 32/64 and then you can build any other dependent tool in 32, 64 or 32/64 universal build as long as you maintain the darwin-x86 convention throughout.
If the problem is that a particular application isn't 64 bit compatible, then that is a problem with that application's support for 64 bit builds and not the universal build system.
-tom
On Dec 21, 2009, at 3:39 PM, Andrew Johnson wrote:
> On Monday 21 December 2009 13:56:09 Eric Norum wrote:
>> To build EPICS for 64-bit only, edit
> I don't recommend this if you're wanting to build and run alh or StripTool
> with the result; AIUI neither of those programs works very well (if at all)
> when built for 64-bit. Janet has fixing them on her To Do list, but I don't
> know how long it's going to take. MEDM seems to be Ok though.
> I guess that's one of the disadvantages of using the Darwin universal 32/64
> build configuration, all the code has to work properly on both configurations.
> - Andrew
> The best FOSS code is written to be read by other humans -- Harald Welte
- Compiling alh, MEDM on Snow Leopard (10.6.2) Bertrand H.J. Biritz
- Re: Compiling alh, MEDM on Snow Leopard (10.6.2) Bertrand H.J. Biritz
- Re: Compiling alh, MEDM on Snow Leopard (10.6.2) Eric Norum
- Re: Compiling alh, MEDM on Snow Leopard (10.6.2) Andrew Johnson
Re: [BUG?] dbgrep *O > /tmp/toto Ralph Lange
<2009>
2025
2026
RE: september cut Jeff Hill
<2009>
2025
2026
