1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Odd MEDM behavior on OS-X
To: Josh Stein <[email protected]>, EPICS tech-talk <[email protected]>
Date: Wed, 6 Jan 2010 14:27:48 -0600
Josh,
It sounds like it's probably a problem with XKeysymDB.   A fix may be
as simple as
   export XKEYSYMDB=/usr/X11R6/lib/X11/XKeysymDB.   (or whereever XkeysymDB is)
--Matt
On Wed, Jan 6, 2010 at 2:12 PM, Mark Rivers <[email protected]> wrote:
> OK, so the problem is with the X server, not the client, since that
> behaviour does not occur when displaying MEDM from the other platform on
> Linux or Windows, right?  Do you know when the problem started?  I am
> not a Mac user, but Lewis Muir and Eric Norum are, so maybe they have
> some ideas?
> -----Original Message-----
> From: Josh Stein [mailto:[email protected]]
> Sent: Wednesday, January 06, 2010 2:10 PM
> To: Mark Rivers
> Cc: EPICS tech-talk
> Good question Mark, and I should have pointed this out before...
> Running MEDM on other platforms while exporting the display back to my
> Mac produces identical results (e.g. those specific buttons are still
> non-functional).
> Mark Rivers wrote:
>> Can you isolate the problem to the X server or client?  What happens
> if
>> you run the same version of medm on a Linux system and display on your
>> Mac, or run medm on your Mac and display on Linux or Windows?
>> Mark
>> From: [email protected]
>> [mailto:[email protected]] On Behalf Of Josh Stein
>> Sent: Wednesday, January 06, 2010 2:02 PM
>> To: EPICS tech-talk
>> Subject: Odd MEDM behavior on OS-X
>> Ok, we're having an odd problem here at APS which has myself and
> others
>> scratching our heads.
>> When running MEDM on my Mac (OS X - Leopard) I am able to open and
>> execute existing screens, but when I try to add an object (using the
>> object pallet) things get bizarre. I am unable to successfully
> interact
>> with any of the object buttons within the palette (so, for example, if
> I
>> wanted to place a static rectangle using the drawing object, I cannot
>> seem to get that button to "press"). All buttons within the object
>> palette are similarly crippled.
>> Other uses of the mouse button within MEDM seem fine - for example
> when
>> a screen is operating and connected to PVs, I can click on related
>> displays, or other controllers and have them function properly.
>> Furthermore the other two palette types (Resource and Color) function
>> fine.
>> I realize I can place objects by right-clicking on the display - but
>> something has changed recently, as I've traditionally always used the
>> object palette.
>> Any ideas? Our Mac people have tried differing versions of the OS with
>> no difference noted.
>> --Josh
Re: Odd MEDM behavior on OS-X Eric Norum
Odd MEDM behavior on OS-X Josh Stein
RE: Odd MEDM behavior on OS-X Mark Rivers
Re: Odd MEDM behavior on OS-X Josh Stein
Prev: Re: Odd MEDM behavior on OS-X Eric Norum
Next: RE: Odd MEDM behavior on OS-X Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: Odd MEDM behavior on OS-X Mark Rivers
Next: Re: Odd MEDM behavior on OS-X Eric Norum
