msi is compiled and working for all of my epics base versions. But dbLoadTemplate directive doesn't work. Do I need to change my CONFIG directory for msi? I remember doing this in the past... The error I get is : dbLoadTemplate("my.substitution")
Error: syntax error
Parsing 'dbl'
in path "." file my.substitution line 1dbl is on the first line of my sub file. I get one error for each of my instance of the template file. Note that if my sub file is empty I still get the same error (or almost, without the dbl). So the files are found, but the parsing is not working correctly. What am I doing wrong? -- Emmanuel
| ANJ, 02 Sep 2010 |
Home
News
About
Talk
Base
Modules
Extensions
