On Wednesday 27 January 2010 14:05:47 Emmanuel Mayssat wrote:
> msi is compiled and working for all of my epics base versions.
Ok. What has that got to do with questions about dbLoadTemplates?
> But dbLoadTemplate directive doesn't work.
The two are not related, other than the fact that both make use of macLib from
libCom internally. That's probably about the only code they have in common.
> Do I need to change my CONFIG directory for msi?
> I remember doing this in the past...
Don't you keep the history of your application sources in CVS or some other
version control system? This shows you one good reason to do so...
> The error I get is :
> dbLoadTemplate("my.substitution")
> Error: syntax error
> Parsing 'dbl'
> in path "." file my.substitution line 1
> dbl is on the first line of my sub file.
Why? dbl is an st.cmd file command; it has nothing to do with the syntax that
dbLoadTemplate() accepts. It is looking for the keyword "file" followed by
the name of a template file. Section 6.20 of the AppDevGuide describes the
formats it understands.
> I get one error for each of my instance of the template file.
> Note that if my sub file is empty I still get the same error (or almost,
> without the dbl).
> So the files are found, but the parsing is not working correctly.
> What am I doing wrong?
If you were meaning to expand your substitution files at build time you would
use msi for that and give it a substitution file, using the same syntax that
dbLoadTemplate() is looking for, and then you probably wouldn't use
dbLoadTemplate() at all on the IOC.
- Andrew
The best FOSS code is written to be read by other humans -- Harald Welte
- Re: dbLoadTemplate issue in 3.14.9-11 Emmanuel Mayssat
- dbLoadTemplate issue in 3.14.9-11 Emmanuel Mayssat
Re: dbLoadTemplate issue in 3.14.9-11 Ralph Lange
<2010>
2025
2026
<2010>
2025
2026
