1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: dbLoadTemplate issue in 3.14.9-11
Cc: [email protected]
Date: Wed, 27 Jan 2010 12:56:59 -0800
Andrew Johnson wrote:
The two are not related, other than the fact that both make use of macLib from libCom internally. That's probably about the only code they have in common.
From a user perspective, don't they expand substitution/template files the same way?
Do I need to change my CONFIG directory for msi?
I remember doing this in the past...
Don't you keep the history of your application sources in CVS or some other version control system? This shows you one good reason to do so...
Thank you for the advice.
I have been using dbLoadTemplate only for testing.
Why? dbl is an st.cmd file command; it has nothing to do with the syntax that dbLoadTemplate() accepts.
dbl is in my template file for testing .... oops... wrong testing entry!
changed to
record (ao, "test") {
If you were meaning to expand your substitution files at build time you would use msi for that and give it a substitution file, using the same syntax that dbLoadTemplate() is looking for, and then you probably wouldn't use dbLoadTemplate() at all on the IOC.
I guess that's a possibility. Thanks, -- E
Re: dbLoadTemplate issue in 3.14.9-11 Ralph Lange
dbLoadTemplate issue in 3.14.9-11 Emmanuel Mayssat
Re: dbLoadTemplate issue in 3.14.9-11 Andrew Johnson
Prev: RE: dbLoadTemplate issue in 3.14.9-11 Mark Rivers
Next: Re: dbLoadTemplate issue in 3.14.9-11 Emmanuel Mayssat
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: dbLoadTemplate issue in 3.14.9-11 Andrew Johnson
Next: Re: dbLoadTemplate issue in 3.14.9-11 Ralph Lange
