> cd /home/clsfs/epics/prod/cls1bpm/epics-lyncean/etc/cls1bpm/msi
> dbLoadTemplate("das640216_beamPositionMonitors_adc1.sub")
Where are these commands being executed, at the Unix shell, IOC shell, etc?
If in the IOC shell why are you cd'ing to the msi directory?
From: [email protected] on behalf of Emmanuel Mayssat
Sent: Wed 1/27/2010 2:44 PM
To: Ralph Lange
Cc: [email protected]
Subject: Re: dbLoadTemplate issue in 3.14.9-11
Ralph,
dbl is actually in my template file (not my substitution file)!
It is actually the only line in my template file (for testing purpose)
I typed the error by hand, my mistake.... the real error is
Error: syntax error
Parsing 'dbl'
in path '.' file das640216_beamPositionMonitors_adcX.dbt line 1
Note:
dbt file = my template file extension
sub = my substitution file extension
I hope this helps
Ralph Lange wrote:
> I'm kind of confused here ...
> What is "dbl" in a substitution file supposed to mean?
> Both allowed syntax variants for substitution files start with a
> "file" directive - see AppDevGuide 6.20.
> Ralph
> On Wed 27 Jan 2010 15:05:47 Emmanuel Mayssat wrote:
>> msi is compiled and working for all of my epics base versions.
>> But dbLoadTemplate directive doesn't work.
>> Do I need to change my CONFIG directory for msi?
>> I remember doing this in the past...
>> The error I get is :
>> dbLoadTemplate("my.substitution")
>> Error: syntax error
>> Parsing 'dbl'
>> in path "." file my.substitution line 1
>> dbl is on the first line of my sub file.
>> I get one error for each of my instance of the template file.
>> Note that if my sub file is empty I still get the same error (or
>> almost, without the dbl).
>> So the files are found, but the parsing is not working correctly.
>> What am I doing wrong?
>> Emmanuel
- dbLoadTemplate issue in 3.14.9-11 Emmanuel Mayssat
- Re: dbLoadTemplate issue in 3.14.9-11 Ralph Lange
- Re: dbLoadTemplate issue in 3.14.9-11 Emmanuel Mayssat
<2010>
2025
2026
<2010>
2025
2026
