In my case FileNumber is not actually read from hardware, it is a value
that can incremented by the driver. There is no hardware state to be
read, and the intial value comes from save/restore.
But my approach works even with hardware, because I am using the
standard asyn device support. Asyn device support for output records
always reads the value from the hardware in init_record. If that read
returns success then the initial value of the output record is set to
the hardware state. Thus, the PINI processing will simply rewrite the
existing hardware value if one was read successfully in init_record, and
it will write the database or save/restore value if the initial read
from hardware failed.
-----Original Message-----
Sent: Thursday, February 11, 2010 12:34 PM
To: Mark Rivers
Cc: Hinko Kocevar; [email protected]
Subject: Re: MBBO update
I love these little database 'snippets'. But what happens when the IOC
is rebooted?
It seems that FileNumber (with PINI=YES) could process first after
iocInit(), causing FileNumber_write to process and send a "1" to the
hardware before FileNumber_RBV tries to read back from the hardware and
set the actual value into FileNumber. Even using autosave would keep
things 'bumpless' only in the case where no external change was made to
the hardware while the IOC down or being rebooted.
It seems like additional logic is required to disable FileNumber until
at least FileNumber_RBV has processed once. Or else declare PINI=NO on
FileNumber.
On 11 Feb 2010, at 05:51 , Mark Rivers wrote:
> Hi Hinko,
> This is a classic problem of having more than one mechanism for
driving an output, and keeping the output PV up-to-date.
> Here is a database fragment that handles this logic (thanks to Tim
Mooney for this).
> FileNumber is the output record, the equivalent of the mbbo record in
your case. Note that it uses soft device support, it does not talk
directly to the hardware. FileNumber_RBV is the input record, the
equivalent of the mbbi record in your case. In my case it it I/O Intr
scanned, i.e. it processes when the hardware driver does a callback to
device support, but it could also be periodically scanned. There are 2
additional records required. FileNumber_write is the record that
actually talks to the hardware. FileNumber_Sync is a record that copies
the readback value from FileNumber_RBV to FileNumber, but WITHOUT
causing the value to be written to the hardware. It works because the
FileNumber_write record has scan disabled if the FileNumber_sync record
is processing (PACT=1). With this logic FileNumber will correctly
reflect the actual state of the hardware, and it can also be written to
change the hardware.
> record(longout, "$(P)$(R)FileNumber")
> field(PINI, "YES")
> field(OUT, "$(P)$(R)FileNumber_write PP")
> field(VAL, "1")
> record(longout, "$(P)$(R)FileNumber_write")
> field(SDIS, "$(P)$(R)FileNumber_Sync.PACT")
> field(DISV, "1")
> field(DTYP, "asynInt32")
> field(OUT, "@asyn($(PORT),$(ADDR),$(TIMEOUT))FILE_NUMBER")
> record(longin, "$(P)$(R)FileNumber_RBV")
> field(INP, "@asyn($(PORT),$(ADDR),$(TIMEOUT))FILE_NUMBER")
> field(SCAN, "I/O Intr")
> field(FLNK, "$(P)$(R)FileNumber_Sync")
> record(longout, "$(P)$(R)FileNumber_Sync")
> field(DOL, "$(P)$(R)FileNumber_RBV NPP")
> field(OMSL, "closed_loop")
> field(OUT, "$(P)$(R)FileNumber PP")
> Mark
> ________________________________
> From: [email protected] on behalf of Hinko Kocevar
> Sent: Thu 2/11/2010 6:27 AM
> To: [email protected]
> Subject: MBBO update
> Hi,
> I'm using mbbo record type that provides 5 values/strings. When mbbo
> record is controlled from EDM panel using Radio Box I can set the
record
> value to desired state.
> If the state changes in the underlying software my mbbo record does
not
> update the value - eg. Radio Box button that was last pressed remains
> selected in the EDM panel, while actual state changed.
> How can this be done?
> Providing mbbi record with same PORT and ADDR as mbbo, I can see that
> the state in mbbi record updates as soon as the underlying software
> changes the value. But this does not update the mbbo record, though..
> Here is the mbbo record:
> record(mbbo, "$(DEVICE)SWITCH") {
> field(OUT, "@asyn($(PORT), 0, 1.0)")
> field(ZRVL, "0")
> field(ONVL, "1")
> field(TWVL, "2")
> field(THVL, "3")
> field(FRVL, "4")
> field(ZRST, "MANUAL")
> field(ONST, "AUTO")
> field(TWST, "AVERAGING")
> field(THST, "COMPENSATING")
> field(FRST, "AVE & COMP")
> field(PINI, "YES")
> Best regards,
> Hinko
> Hinko Kocevar
> Technical support software engineer
> Instrumentation Technologies
> Velika pot 22, SI-5250 Solkan - Slovenia
> T:+386 5 3352600, F:+386 5 3352601
> mailto: [email protected]
> http://www.i-tech.si <http://www.i-tech.si/> - When your users demand
stability
> The information transmitted is intended solely for the addressee and
may
> contain confidential and/or privileged information. Any review,
retention,
> disclosure or other use by persons other than the intended recipient
is
> prohibited. If you received this in error, please notify the sender
and
> delete all copies.
- MBBO update Hinko Kocevar
- RE: MBBO update Mark Rivers
- Re: MBBO update Stephen Lewis
Re: MBBO update Hinko Kocevar
<2010>
2025
2026
EPICS_CA_MAX_ARRAY_BYTES Matthieu Bec
<2010>
2025
2026
