Thanks Mark and Ralph I'll try it out and come back to you.
Best regards,
Hinko
Ralph Lange wrote:
> Hello Hinko,
> Some device supports, which are connecting to hardware capable of
> running in a multi-master setup, achieve this by processing the passive
> output record when a value update comes in from the hardware:
> In the interrupt handler, device support sets a flag in its private
> structure and issues a scan request for the record, i.e. it basically
> fakes the second part of an asynchronous operation. When the record is
> being processed, device support checks the flag and updates the record
> with the value from the hardware (instead of writing from the record to
> the hardware).
> Works flawlessly, does not need additional records, but of course
> doesn't solve the classic race condition when two masters (IOC and the
> other guy) try to write at the same time.
> Cheers,
> Ralph
> On Thu 11 Feb 2010 8:51:55 Mark Rivers wrote:
>> Hi Hinko,
>> This is a classic problem of having more than one mechanism for
>> driving an output, and keeping the output PV up-to-date.
>> Here is a database fragment that handles this logic (thanks to Tim
>> Mooney for this).
>> FileNumber is the output record, the equivalent of the mbbo record in
>> your case. Note that it uses soft device support, it does not talk
>> directly to the hardware. FileNumber_RBV is the input record, the
>> equivalent of the mbbi record in your case. In my case it it I/O Intr
>> scanned, i.e. it processes when the hardware driver does a callback to
>> device support, but it could also be periodically scanned. There are 2
>> additional records required. FileNumber_write is the record that
>> actually talks to the hardware. FileNumber_Sync is a record that
>> copies the readback value from FileNumber_RBV to FileNumber, but
>> WITHOUT causing the value to be written to the hardware. It works
>> because the FileNumber_write record has scan disabled if the
>> FileNumber_sync record is processing (PACT=1). With this logic
>> FileNumber will correctly reflect the actual state of the hardware,
>> and it can also be written to change the hardware.
>> record(longout, "$(P)$(R)FileNumber")
>> field(PINI, "YES")
>> field(OUT, "$(P)$(R)FileNumber_write PP")
>> field(VAL, "1")
>> record(longout, "$(P)$(R)FileNumber_write")
>> field(SDIS, "$(P)$(R)FileNumber_Sync.PACT")
>> field(DISV, "1")
>> field(DTYP, "asynInt32")
>> field(OUT, "@asyn($(PORT),$(ADDR),$(TIMEOUT))FILE_NUMBER")
>> record(longin, "$(P)$(R)FileNumber_RBV")
>> field(INP, "@asyn($(PORT),$(ADDR),$(TIMEOUT))FILE_NUMBER")
>> field(SCAN, "I/O Intr")
>> field(FLNK, "$(P)$(R)FileNumber_Sync")
>> record(longout, "$(P)$(R)FileNumber_Sync")
>> field(DOL, "$(P)$(R)FileNumber_RBV NPP")
>> field(OMSL, "closed_loop")
>> field(OUT, "$(P)$(R)FileNumber PP")
>> Mark
Hinko Kocevar
Technical support software engineer
Instrumentation Technologies
Velika pot 22, SI-5250 Solkan - Slovenia
T:+386 5 3352600, F:+386 5 3352601
mailto: [email protected]
http://www.i-tech.si - When your users demand stability
The information transmitted is intended solely for the addressee and may
contain confidential and/or privileged information. Any review, retention,
disclosure or other use by persons other than the intended recipient is
prohibited. If you received this in error, please notify the sender and
delete all copies.
- MBBO update Hinko Kocevar
- RE: MBBO update Mark Rivers
- Re: MBBO update Ralph Lange
EPICS/asyn problem Mark Rivers
<2010>
2025
2026
Re: MBBO update Hinko Kocevar
<2010>
2025
2026
