1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: MBBO update
To: Hinko Kocevar <[email protected]>
Cc: [email protected]
Date: Thu, 11 Feb 2010 12:45:05 -0500
Hello Hinko,
Some device supports, which are connecting to hardware capable of running in a multi-master setup, achieve this by processing the passive output record when a value update comes in from the hardware:
In the interrupt handler, device support sets a flag in its private structure and issues a scan request for the record, i.e. it basically fakes the second part of an asynchronous operation. When the record is being processed, device support checks the flag and updates the record with the value from the hardware (instead of writing from the record to the hardware).
Works flawlessly, does not need additional records, but of course doesn't solve the classic race condition when two masters (IOC and the other guy) try to write at the same time.
Cheers,
Ralph
On Thu 11 Feb 2010 8:51:55 Mark Rivers wrote:
Hi Hinko,
This is a classic problem of having more than one mechanism for driving an output, and keeping the output PV up-to-date.
Here is a database fragment that handles this logic (thanks to Tim Mooney for this).
FileNumber is the output record, the equivalent of the mbbo record in your case. Note that it uses soft device support, it does not talk directly to the hardware. FileNumber_RBV is the input record, the equivalent of the mbbi record in your case. In my case it it I/O Intr scanned, i.e. it processes when the hardware driver does a callback to device support, but it could also be periodically scanned. There are 2 additional records required. FileNumber_write is the record that actually talks to the hardware. FileNumber_Sync is a record that copies the readback value from FileNumber_RBV to FileNumber, but WITHOUT causing the value to be written to the hardware. It works because the FileNumber_write record has scan disabled if the FileNumber_sync record is processing (PACT=1). With this logic FileNumber will correctly reflect the actual state of the hardware, and it can also be written to change the hardware.
record(longout, "$(P)$(R)FileNumber")
field(PINI, "YES")
field(OUT, "$(P)$(R)FileNumber_write PP")
field(VAL, "1")
record(longout, "$(P)$(R)FileNumber_write")
field(SDIS, "$(P)$(R)FileNumber_Sync.PACT")
field(DISV, "1")
field(DTYP, "asynInt32")
field(OUT, "@asyn($(PORT),$(ADDR),$(TIMEOUT))FILE_NUMBER")
record(longin, "$(P)$(R)FileNumber_RBV")
field(INP, "@asyn($(PORT),$(ADDR),$(TIMEOUT))FILE_NUMBER")
field(SCAN, "I/O Intr")
field(FLNK, "$(P)$(R)FileNumber_Sync")
record(longout, "$(P)$(R)FileNumber_Sync")
field(DOL, "$(P)$(R)FileNumber_RBV NPP")
field(OMSL, "closed_loop")
field(OUT, "$(P)$(R)FileNumber PP")
Re: MBBO update Hinko Kocevar
RE: MBBO update Mark Rivers
Prev: EPICS_CA_MAX_ARRAY_BYTES Matthieu Bec
Next: Re: MBBO update Stephen Lewis
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: MBBO update Mark Rivers
Next: Re: MBBO update Hinko Kocevar
