1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: MBBO update
To: Ralph Lange <[email protected]>
Cc: [email protected]
Date: Fri, 05 Mar 2010 17:36:55 +0100
Hi Ralph,
Ralph Lange wrote:
>> record(longout, "$(P)$(R)FileNumber")
>>     field(PINI, "YES")
>>     field(OUT, "$(P)$(R)FileNumber_write PP")
>>     field(VAL, "1")
>> record(longout, "$(P)$(R)FileNumber_write")
>>     field(SDIS, "$(P)$(R)FileNumber_Sync.PACT")
>>     field(DISV, "1")
>>     field(DTYP, "asynInt32")
>>     field(OUT, "@asyn($(PORT),$(ADDR),$(TIMEOUT))FILE_NUMBER")
>> record(longin, "$(P)$(R)FileNumber_RBV")
>>     field(INP,  "@asyn($(PORT),$(ADDR),$(TIMEOUT))FILE_NUMBER")
>>     field(SCAN, "I/O Intr")
>>     field(FLNK, "$(P)$(R)FileNumber_Sync")
>> record(longout, "$(P)$(R)FileNumber_Sync")
>>     field(DOL,  "$(P)$(R)FileNumber_RBV NPP")
>>     field(OMSL, "closed_loop")
>>     field(OUT,  "$(P)$(R)FileNumber PP")
>> Mark
I've tried your solution on my hardware and it works like a charm! Even
with mbbo and mbbi record types.
Thank you!
Best regards,
Hinko
Hinko Kocevar
Technical support software engineer
Instrumentation Technologies
Velika pot 22, SI-5250 Solkan - Slovenia
T:+386 5 3352600, F:+386 5 3352601
mailto: [email protected]
http://www.i-tech.si - When your users demand stability
The information transmitted is intended solely for the addressee and may
contain confidential and/or privileged information. Any review, retention,
disclosure or other use by persons other than the intended recipient is
prohibited. If you received this in error, please notify the sender and
delete all copies.
MBBO update Hinko Kocevar
RE: MBBO update Mark Rivers
Re: MBBO update Ralph Lange
Prev: 2 MAXv problems Jens . Eden
Next: Re: ChannelArchiver on Solaris? Matthias Clausen
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: MBBO update Hinko Kocevar
Next: Re: MBBO update Stephen Lewis
