1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: 2 MAXv problems
To: [email protected]
Date: Fri, 5 Mar 2010 17:08:32 +0100
Hi all,
I found, that in recent firmware versions (1.31) of the MAXv cards the
command to set
negative encoder resolutions (e.g. "AX ER-2,3") as used by the MAXv driver
does not work any more.
Instead a command error is returned and the encoder resolution will remain
unchanged.
I couldn't find this "new feature" documented anywhere.
For the MAXp-card I verified, that this behaviour was introduced between
firmware versions 1.29 and 1.31.
The workaround is to not use negative encoder resolution, instead reverse
the encoder direction
with the new EDI command in the init-string.
If using RTEMS the ioc crashes, when calling sprintf in interrupt context
(motorIsr() in drvMAXv.cc) .
I assume, calling sprintf() in interrupt context is not allowed in RTEMS?
Jens
Re: 2 MAXv problems Ron Sluiter
Re: 2 MAXv problems Joachim Rahn
Prev: Re: compile error with medm 3.1.3 on fedora 10 Robert Soliday
Next: Re: MBBO update Hinko Kocevar
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: ChannelArchiver on Solaris? Matthias Clausen
Next: Re: 2 MAXv problems Ron Sluiter
