1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: 2 MAXv problems
To: [email protected]
Cc: [email protected]
Date: Fri, 05 Mar 2010 14:12:43 -0600
Hello Jens
There has been a recent (R6-4 and above) fix to prevent intermittent MAXv command
errors from occurring when User Units are turned off, but the motor record has not
issued negative encoder ratio commands for a long time. Are you using a really old
version of the motor record?
Ron
[email protected] wrote:
Hi all,
I found, that in recent firmware versions (1.31) of the MAXv cards the command to set
negative encoder resolutions (e.g. "AX ER-2,3") as used by the MAXv driver does not work any more.
Instead a command error is returned and the encoder resolution will remain unchanged.
I couldn't find this "new feature" documented anywhere.
Re: 2 MAXv problems Jens . Eden
Prev: Re: ChannelArchiver on Solaris? Ralph Lange
Next: Re: ChannelArchiver on Solaris? Matthias Clausen
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: 2 MAXv problems Jens . Eden
Next: Re: 2 MAXv problems Jens . Eden
