Hello Ron,
> but the motor record has not issued negative
> encoder ratio commands for a long time.
here is an extract of the boot messages with
drvMAXvdebug=10, while autosave writes
-5.55123456e-06 to the ERES-field.
send_mess: sent card 0 message:'
AX ER-180140,52359 UU-3.440496
This command (ER-180140,52359) does not work for
current firmware versions.
> Are you using a really old
> version of the motor record?
No, this is the
motorR6-4-4
EpicsRelease 3.14.11
Jens
_______________________________
Jens Eden
Physikalisch-Technische Bundesanstalt
Albert-Einstein-Straße 15
12489 Berlin
Tel +49 30 6392-5086
Fax +49 30 6392-5082
Von:
Ron Sluiter <[email protected]>
An:
[email protected]
Kopie:
[email protected]
Datum:
05.03.2010 21:12
Betreff:
Re: 2 MAXv problems
Hello Jens
There has been a recent (R6-4 and above) fix to prevent intermittent
MAXv command
errors from occurring when User Units are turned off, but the motor
record has not
issued negative encoder ratio commands for a long time. Are you using a
really old
Ron
[email protected] wrote:
> Hi all,
> I found, that in recent firmware versions (1.31) of the MAXv cards the
> command to set
> negative encoder resolutions (e.g. "AX ER-2,3") as used by the MAXv
driver
> does not work any more.
> Instead a command error is returned and the encoder resolution will
remain
> unchanged.
> I couldn't find this "new feature" documented anywhere.
- Re: 2 MAXv problems Ron Sluiter
- 2 MAXv problems Jens . Eden
Re: ChannelArchiver on Solaris? Matthias Clausen
Problem while Launching EDM Hiren Patel
<2010>
2025
2026
<2010>
2025
2026
