Subject: |
Re: Epics Base 3.14.9 compilation errors for Fedora 11 64 bit version |
Ramu Denduluri <[email protected]> |
To: |
[email protected] |
Date: |
Tue, 23 Feb 2010 17:50:02 -0500 |
Hi Andrew,
The details you gave helped me in compiling Epics Base 3.14.9 on
64 bit Fedora 11. Yes, we will be using it for Channel Access Clients
only.
The shared libraries were installed, however the softlink was
pointing to non-existing library. I changed it to point to the correct
library and compiled the code. Thank you very much.
Best Regards,
Ramu
Andrew Johnson wrote:
Hi Ramu,
On Monday 22 February 2010 18:59:03 Ramu Denduluri wrote:
I was trying to compile Epics base 3.14.9 on 64 bit Fedora 11 operating
system and got compilation errors as follows:
We don't have access to any Fedora 11 systems here so what I say below might
not be quite right, but we suspect that you're missing an RPM and that the
error you're getting isn't an EPICS issue as such.
However I would advise you that Base R3.14.9 built for a 64-bit machine should
*only* be used for Channel Access clients (and be aware that some of the
standard clients like StripTool and ALH may not work on 64-bit at all yet);
the IOC code was not properly patched to work on 64-bit until R3.14.10.
/usr/bin/ld:
/usr/lib/gcc/x86_64-redhat-linux/4.4.1/libstdc++.a(stdexcept.o):
relocation R_X86_64_32S against `vtable for std::runtime_error' can not
be used when making a shared object; recompile with -fPIC
/usr/lib/gcc/x86_64-redhat-linux/4.4.1/libstdc++.a: could not read
symbols: Bad value
Does your /usr/lib/gcc/x86_64-redhat-linux/4.4.1/ directory contain any files
or soft links with names starting "libstdc++.so"? If soft-links, where do
they point to? You can run these commands (replacing my 4.1.1 with 4.4.1 and
adjust the number after the .so as necessary) and compare their output to
mine:
tux% file /usr/lib/gcc/x86_64-redhat-linux/4.1.1/libstdc++.so
/usr/lib/gcc/x86_64-redhat-linux/4.1.1/libstdc++.so: symbolic link to
`../../../../lib64/libstdc++.so.6.0.8'
tux% file /usr/lib64/libstdc++.so.6.0.8
/usr/lib64/libstdc++.so.6.0.8: ELF 64-bit LSB shared object, AMD x86-64,
version 1 (SYSV), stripped
My machine tux is a RHEL5 64-bit system and has two separate RPMs which are
relevant to this issue:
tux% rpm -qf /usr/lib/gcc/x86_64-redhat-linux/4.1.1/libstdc++.so
gcc-c++-4.1.2-46.el5
tux% rpm -qf /usr/lib64/libstdc++.so.6.0.8
libstdc++-4.1.2-46.el5
I suspect you are missing the .so file completely, in which case you'll need
to install the FC11 versions of one or more of the above packages.
- Andrew
- Epics Base 3.14.9 compilation errors for Fedora 11 64 bit version Ramu Denduluri
- Re: Epics Base 3.14.9 compilation errors for Fedora 11 64 bit version Andrew Johnson
marccd driver Song, Jinhu
<2010>
2025
2026
<2010>
2025
2026
ANJ, 02 Sep 2010 |
Home
News
About
Talk
Base
Modules
Extensions
Distributions
Download
Documents
Links
Licensing
