1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Compilation errors associated to medm 3.1.3 on 64 bit Fedora 11 operating system.
To: [email protected]
Date: Mon, 01 Mar 2010 18:29:15 -0500
Hi All,
While installing the medm 3.1.3 on 64 bit Fedora 11 operation system, I got following compilation error.
gcc -ansi -pedantic -D_POSIX_C_SOURCE=199506L -O3 -Wall -DEDITRES -D_X86_64_ -Dlinux -fPIC -D_REENTRANT -DUNIX -D_BSD_SOURCE -I. -I.. -I../../printUtils -I../../xc -I -I -I../../../../include/os/Linux -I../../../../include -I/home/clsfs/epics/prod/cr1dev3/epics-base-3.14.11/include/os/Linux -I/home/clsfs/epics/prod/cr1dev3/epics-base-3.14.11/include -c ../utils.c
../utils.c: In function 'doRubberbanding':
../utils.c:965: warning: cast from pointer to integer of different size
../utils.c: In function 'doDragging':
../utils.c:1160: warning: cast from pointer to integer of different size
../utils.c: In function 'doPasting':
../utils.c:1400: warning: cast from pointer to integer of different size
../utils.c: In function 'doResizing':
../utils.c:1658: warning: cast from pointer to integer of different size
../utils.c: In function 'parseAndExecCommand':
../utils.c:4268: warning: the address of 'command' will always evaluate as 'true'
../utils.c:4743:2: error: #error getEventType only works for LASTEvent=35 (See X.h)
make[2]: *** [utils.o] Error 1
make[2]: Leaving directory `/usr/local/src/epics-extensions-3.14.11-20100224_114640/src/medm-3.1.1/medm/O.linux-x86_64'
make[1]: *** [buildInstall.linux-x86_64] Error 2
make[1]: Leaving directory `/usr/local/src/epics-extensions-3.14.11-20100224_114640/src/medm-3.1.1/medm'
make: *** [medm.buildInstall] Error 2
I am using epics-base 3.14.11 and could you please help me in fixing this issue.
Best Regards,
Ramu
Re: Compilation errors associated to medm 3.1.3 on 64 bit Fedora 11 operating system. J. Lewis Muir
Prev: Re: aSubRecord Andrew Johnson
Next: edm table collapsing Pierrick Hanlet
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Re: Compilation errors associated to medm 3.1.3 on 64 bit Fedora 11 operating system. J. Lewis Muir
