I'm using 3.14.11 on a linux system with a soft ioc. I am using edm table. Until recently, the table
worked as advertised, but upon changing the size of the display and then the size of the table, I
find that the table will print successfully once, then when updating after a scan will collapse to a
box 2mm X 2mm. Has anyone ever seen this before? More importantly, how do I fix it?
Resizing doesn't help.
Thank you,
Pierrick
Pierrick Hanlet
Fermilab, P.O. Box 500, M.S. 122
Batavia, IL 60510
[email protected]
(630)840-5555/8871/6039 office/lab/fax
http://www-d0.fnal.gov/~hanlet
"Whether you think you can or think you can't, either way, you are correct" -- Henry Ford
Compilation errors associated to medm 3.1.3 on 64 bit Fedora 11 operating system. Ramu Denduluri
Re: Compilation errors associated to medm 3.1.3 on 64 bit Fedora 11 operating system. J. Lewis Muir
<2010>
2025
2026
compile error with medm 3.1.3 on fedora 10 Hitesh
<2010>
2025
2026
