Subject: |
Re: Compilation errors associated to medm 3.1.3 on 64 bit Fedora 11 operating system. |
"J. Lewis Muir" <[email protected]> |
To: |
[email protected] |
Date: |
Tue, 02 Mar 2010 09:32:39 -0600 |
On 3/1/10 5:29 PM, Ramu Denduluri wrote:
> Hi All,
> While installing the medm 3.1.3 on 64 bit Fedora 11 operation
> system, I got following compilation error.
> gcc -ansi -pedantic -D_POSIX_C_SOURCE=199506L -O3 -Wall
> -DEDITRES -D_X86_64_ -Dlinux -fPIC -D_REENTRANT -DUNIX -D_BSD_SOURCE
> -I. -I.. -I../../printUtils -I../../xc -I -I
> -I../../../../include/os/Linux -I../../../../include
> -I/home/clsfs/epics/prod/cr1dev3/epics-base-3.14.11/include/os/Linux
> -I/home/clsfs/epics/prod/cr1dev3/epics-base-3.14.11/include -c
> ../utils.c
> ../utils.c: In function 'doRubberbanding':
> ../utils.c:965: warning: cast from pointer to integer of different size
> ../utils.c: In function 'doDragging':
> ../utils.c:1160: warning: cast from pointer to integer of different size
> ../utils.c: In function 'doPasting':
> ../utils.c:1400: warning: cast from pointer to integer of different size
> ../utils.c: In function 'doResizing':
> ../utils.c:1658: warning: cast from pointer to integer of different size
> ../utils.c: In function 'parseAndExecCommand':
> ../utils.c:4268: warning: the address of 'command' will always evaluate
> as 'true'
> ../utils.c:4743:2: error: #error getEventType only works for
> LASTEvent=35 (See X.h)
> make[2]: *** [utils.o] Error 1
> make[2]: Leaving directory
> `/usr/local/src/epics-extensions-3.14.11-20100224_114640/src/medm-3.1.1/medm/O.linux-x86_64'
> make[1]: *** [buildInstall.linux-x86_64] Error 2
> make[1]: Leaving directory
> `/usr/local/src/epics-extensions-3.14.11-20100224_114640/src/medm-3.1.1/medm'
> make: *** [medm.buildInstall] Error 2
> I am using epics-base 3.14.11 and could you please help me in fixing
> this issue.
Hi, Ramu.
I think upgrading to MEDM 3.1.4 will fix this. See this Tech-Talk thread:
http://www.aps.anl.gov/epics/tech-talk/2009/msg00268.php
Lewis
- Compilation errors associated to medm 3.1.3 on 64 bit Fedora 11 operating system. Ramu Denduluri
edm table collapsing Pierrick Hanlet
compile error with medm 3.1.3 on fedora 10 Hitesh
<2010>
2025
2026
<2010>
2025
2026
