1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Building EPICS for multiple Linux distributions
To: [email protected]
Date: Wed, 10 Mar 2010 12:16:03 -0600
I have implemented a system like this for the beamlines at the APS but warn that this gets a bit messy. Actually it turns out that setting this up is fairly trivial but using it gets to be a bit of a pain. As you said, on the build side this is basically just creating the new architecture files for the different builds and setting your host arch properly. In our case we ended up with linux-x86-fc4(now defunct), linux-x86-fc6 and linux-x86_64-el5, (we had solaris-sparc-v10-gnu, solaris-sparc-v09-gnu, and solaris-x86-v10-gnu as well). After copying the correct files (i.e. CONFIG.Common.linux-x86-fc6, CONFIG.linux-x86-fc6.Common, CONFIG.linux-x86-fc6.linux-x86-fc6, CONFIG_SITE.linux-x86-fc6.linux-x86-fc6) from there originals I basically just set the EPICS_HOST_ARCH and then did make on an appropriate host. This got us through a fair number of incompatibilites in the systems.
The downside of this is now maintenance and use. On the use side I set up some scripts to analyze the system type and set the appropriate host arch. On the maintenance side it depends alot on the size of the facility and your ability to limit what kind of systems are out there. You may face the problem of not being able to advance everyone at the same time and then figure out keeping the environment for all users correct.
HTH,
John
On 3/10/2010 8:45 AM, John Dobbins wrote:
I was wondering if anyone can suggest an approach for building EPICS on multiple linux distributions (which may have different kernel versions, compiler versions, etc.)
Does one define new architectures linux-x86-distribution_a linux-x86-distribution_b?
John Dobbins
Lab for Elementary Particle Physics
Cornell University
-- John Hammonds Beamline Controls and Data Acquisition Group APS Engineering Support Division
Argonne National Laboratory
[email protected]<mailto:[email protected]>
(630)252-5317
Building EPICS for multiple Linux distributions John Dobbins
Prev: Re: 2 MAXv problems Ron Sluiter
Next: Re: Building EPICS for multiple Linux distributions Andrew Johnson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Building EPICS for multiple Linux distributions John Dobbins
