1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Building EPICS for multiple Linux distributions
To: [email protected]
Date: Wed, 10 Mar 2010 12:21:53 -0600
Hi John,
On Wednesday 10 March 2010 08:45:01 John Dobbins wrote:
> I was wondering if anyone can suggest an approach for building EPICS on
> multiple linux distributions (which may have different kernel versions,
> compiler versions, etc.)
> Does one define new architectures linux-x86-distribution_a
> linux-x86-distribution_b?
If you find that you do actually need to build different binaries on different
distributions then that is probably the best way to do it, although you should
not need to do that for every distribution.  We have not had to introduce
anything like that here at the APS, although our Linux distributions are all
either Fedora Core or Red-Had Enterprise based.  These have so far proven to
be completely forward compatible, provided we install the distribution's
relevant compatibility packages to provide the older .so libraries.  We
usually build shared code on the oldest distribution that we need to support,
and find that it then just works on all our machines running newer versions.
Note that a different kernel version should almost never require a change to
user-level application code, although some system utilities do need to match
particular kernel releases.  The Linux distributors seem to have solved most
compatibility problems, and in my experience if I have a problem running
binaries on a different machine it usually means it's missing an RPM.
HTH,
- Andrew
The best FOSS code is written to be read by other humans -- Harald Welte
Re: Building EPICS for multiple Linux distributions Robert Soliday
Re: Building EPICS for multiple Linux distributions Steven M. Hartman
Building EPICS for multiple Linux distributions John Dobbins
Prev: Re: Building EPICS for multiple Linux distributions John Hammonds
Next: Re: Building EPICS for multiple Linux distributions Robert Soliday
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
