1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Building StreamDevice 2-4 / SynApps / Win32
To: [email protected]
Date: Fri, 12 Mar 2010 09:29:53 -0600
On 3/12/10 4:04 AM, Dirk Zimoch wrote:
> John,
> I have verified that "r was unexpected at this time" is an error message
> from the windows command interpreter. I put this (bash) code into a
> *.bat file:
> for r in a b c; do echo $r; done
> and executed the bat file and got the same error message.
> I have no idea how the windows shell works. Better use bash from cygwin.
Hi, Dirk.
But what do you mean by "Better use bash from cygwin?"  Are you
suggesting that John should run "make" from a bash shell from Cygwin?
That's what I'm saying is not what I would expect to make a difference.
 What's important is what shell make is using to execute the commands
for each target.  This is why I suggested checking what the default
shell is for the make included with GnuWin32 and checking if the SHELL
make variable had been set and, if so, to what?
>From what you've said above, it looks like perhaps make is using the
Windows command interpreter as the shell rather than a Bourne shell.  So
if John were to set the make SHELL variable to /bin/sh (or wherever it
is for GnuWin32) then perhaps his problem would be solved.
Lewis
Building StreamDevice 2-4 / SynApps / Win32 John Dobbins
RE: Building StreamDevice 2-4 / SynApps / Win32 Mark Rivers
RE: Building StreamDevice 2-4 / SynApps / Win32 John Dobbins
Re: Building StreamDevice 2-4 / SynApps / Win32 Dirk Zimoch
Prev: Re: Building StreamDevice 2-4 / SynApps / Win32 J. Lewis Muir
Next: Re: Building StreamDevice 2-4 / SynApps / Win32 John Dobbins
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Building StreamDevice 2-4 / SynApps / Win32 Dirk Zimoch
