J. Lewis Muir wrote:
On 3/11/10 10:55 PM, Mark Rivers wrote:
I don't think shell is important on Windows, you can build EPICS in a
Cygwin bash shell or a Windows cmd shell without having to worry about
it.
Hi, Mark.
Note I'm not talking about the shell from which the make command is
executed; I'm talking about the shell that make uses to execute commands
for a given target.
Lewis
Lewis, Mark, All,
It seems to me that an easy thing would be to write a Perl script that replicates this code (which is just generating a test file):
# create stream.dbd from all RECORDS
$(COMMON_DIR)/$(LIBRARY_DEFAULT).dbd: ../CONFIG_STREAM
@for r in $(RECORDS); \
do
echo "device($$r,INST_IO,dev$${r}Stream,\"stream\")"; \
done > $@
@echo "driver(stream)" >> $@
@echo "variable(streamDebug, int)" >> $@
@echo "registrar(streamRegistrar)" >> $@
endif
I can do that but am not sure about how to invoke the Perl script and pass from $(RECORDS) to the Perl script.
It would be nice to not have this one part of EPICS dependent on cygwin when the rest it not.
John
- Re: Building StreamDevice 2-4 / SynApps / Win32 J. Lewis Muir
- Building StreamDevice 2-4 / SynApps / Win32 John Dobbins
- RE: Building StreamDevice 2-4 / SynApps / Win32 Mark Rivers
- RE: Building StreamDevice 2-4 / SynApps / Win32 John Dobbins
- Re: Building StreamDevice 2-4 / SynApps / Win32 John Dobbins
<2010>
2025
2026
<2010>
2025
2026
ANJ, 02 Sep 2010 |
Home
News
About
Talk
Base
Modules
Extensions
Distributions
Download
Documents
Links
Licensing
