Subject: |
Re: Building StreamDevice 2-4 / SynApps / Win32 |
John Dobbins <[email protected]> |
To: |
EPICS Tech-Talk <[email protected]> |
Date: |
Fri, 12 Mar 2010 14:47:05 -0500 |
First, thanks to everyone for the help with understanding what the problem was in the first place, i.e. that one of the StreamDevice Makefiles depends on certain shell capabilities.
I like the fact that I have been able to build EPICS on Windows with the only the dependencies being GnuMake and Perl. So what I have done is to change the StreamDevice Makefile to call two new Perl scripts. My Makefile for the StreamDevice src directory now looks like:
MAKE_STREAM_DBD_CMD = "../makeStreamDbd.pl"
MAKE_STREAM_REFERENCES_CMD = "../makeStreamReferences.pl"
streamReferences: ../CONFIG_STREAM
@$(MAKE_STREAM_REFERENCES_CMD) $(BUSSES) : $(FORMATS)
# create stream.dbd from all RECORDS
$(COMMON_DIR)/$(LIBRARY_DEFAULT).dbd: ../CONFIG_STREAM
@$(MAKE_STREAM_DBD_CMD) $(COMMON_DIR) $(LIBRARY_DEFAULT) $(RECORDS)
I have attached the the Perl scripts I created.
Feel free to suggest improvements that would make this better conform to the standards of the EPICS build system.
John Dobbins
John Dobbins wrote:
Dear All,
I am trying to build StreamDevice 2-4 on win32-x86
I happen to be using the synApps source and the Makefile is show below
The directories structure is:
support/
asyn
std
stream
Everything works fine until I get to stream at which point I get the cryptic error "r was unexpected at this time."
details:
make[4]: Entering directory `W:/winDev/epics/R3.14.10/support/stream/2-4/StreamDevice-2-4/src/O.win32-x86'
make[4]: *** [../O.Common/stream.dbd] Error 255
make[4]: Leaving directory `W:/winDev/epics/R3.14.10/support/stream/2-4/StreamDevice-2-4/src/O.win32-x86'
make[3]: *** [install.win32-x86] Error 2
make[3]: Leaving directory `W:/winDev/epics/R3.14.10/support/stream/2-4/StreamDevice-2-4/src'
make[2]: *** [src.install] Error 2
make[2]: Leaving directory `W:/winDev/epics/R3.14.10/support/stream/2-4/StreamDevice-2-4'
make[1]: *** [StreamDevice-2-4.install] Error 2
make[1]: Leaving directory `W:/winDev/epics/R3.14.10/support/stream/2-4'
make: *** [W:/winDev/epics/R3.14.10/support/stream/2-4.install] Error 2
W:/winDev/epics/R3.14.10/support/stream/2-4/StreamDevice-2-4/src/O.win32-x86' looks like
#This Makefile created by makeMakefile.pl
all :
$(MAKE) -f ../Makefile TOP=../../.. T_A=win32-x86 $@
.DEFAULT: force
force: ;
Advice anyone?
John Dobbins
Lab for Elementary Particle Physics
Cornell University
#FILENAME: Makefile
#USAGE: Top Makefile
#Version: 1.5
#Modified By: mooney
#Last Modified: 2009/03/06 21:31:25
#NOTES- The "SUPPORT_DIRS" order is based on compile time dependencies.
# - The user must modify SUPPORT and EPICS_BASE in the
# <synApps>/support/configure directory for the local configuration.
# - To support multiple configurations, use multiple configure* directories
# - Support modules can be shared between configurations only if
# dependencies are not violated. Only the "DIRS" are the target of
# gnumake. If this configuration is using a support module built by
# another configuration, then the SUPPORT_DIRS line for that support
# module must be commented out (i.e, must begin with a '#').
# Note the only dependencies that matter in $(<module>)_DEPEND_DIRS are
# compile-time dependencies.
TOP = .
MASTER_FILE = $(TOP)/configure/RELEASE.win32-x86
include $(TOP)/configure/CONFIG
###### 1st Tier Support Modules - Only Depend on EPICS BASE ######
SUPPORT_DIRS += $(SNCSEQ)
RELEASE_FILES += $(SNCSEQ)/configure/RELEASE.win32-x86
SUPPORT_DIRS += $(SSCAN)
RELEASE_FILES += $(SSCAN)/configure/RELEASE.win32-x86
SUPPORT_DIRS += $(AUTOSAVE)
RELEASE_FILES += $(AUTOSAVE)/configure/RELEASE.win32-x86
###### 2nd Tier Support Modules - Only Depend on 1st Tier ########
SUPPORT_DIRS += $(ASYN)
RELEASE_FILES += $(ASYN)/configure/RELEASE.win32-x86
$(ASYN)_DEPEND_DIRS = $(SNCSEQ)
SUPPORT_DIRS += $(CALC)
RELEASE_FILES += $(CALC)/configure/RELEASE.win32-x86
$(CALC)_DEPEND_DIRS = $(SSCAN)
################### 3rd Tier Support Modules #####################
SUPPORT_DIRS += $(BUSY)
RELEASE_FILES += $(BUSY)/configure/RELEASE.win32-x86
$(BUSY)_DEPEND_DIRS = $(ASYN)
SUPPORT_DIRS += $(STD)
RELEASE_FILES += $(STD)/configure/RELEASE.win32-x86
$(STD)_DEPEND_DIRS = $(ASYN)
SUPPORT_DIRS += $(STREAM)
RELEASE_FILES += $(STREAM)/configure/RELEASE.win32-x86
$(STREAM)_DEPEND_DIRS = $(ASYN) $(CALC) $(SSCAN)
################### 4th Tier Support Modules #####################
#SUPPORT_DIRS += $(MCA)
#RELEASE_FILES += $(MCA)/configure/RELEASE.win32-x86
#$(MCA)_DEPEND_DIRS = $(ASYN) $(STD)
################### 5th Tier Support Modules #####################
#SUPPORT_DIRS += $(AREA_DETECTOR)
#RELEASE_FILES += $(AREA_DETECTOR)/configure/RELEASE.win32-x86
#$(AREA_DETECTOR)_DEPEND_DIRS = $(ASYN) $(SSCAN) $(MCA)
################### End of Support-Modules #####################
DIRS = $(SUPPORT_DIRS)
################### User Modules #####################
ACTIONS += uninstall realuninstall distclean cvsclean
include $(EPICS_BASE)/configure/RULES_TOP
release:
echo SUPPORT=$(SUPPORT)
echo ' '
echo EPICS_BASE=$(EPICS_BASE)
echo ' '
echo MASTER_FILE=$(MASTER_FILE)
echo ' '
echo DIRS=$(DIRS)
echo ' '
echo RELEASE_FILES=$(RELEASE_FILES)
echo ' '
$(PERL) $(TOP)/configure/makeReleaseConsistent.pl $(SUPPORT) $(EPICS_BASE) $(MASTER_FILE) $(RELEASE_FILES)
$common_dir = $ARGV[0];
$file_name = $ARGV[1];
@records = @ARGV[2..$#ARGV];
unless( open( OUTFILE, ">$common_dir/$file_name.dbd")) { print "makeStreamDbd.pl couldn't open output file\n";}
foreach ( @records )
$r = $_;
$out_line = "device(" .+ $r .+ ",INST_IO,device" .+ $r .+ "Stream,\"stream\")\n";
print OUTFILE $out_line;
print OUTFILE "driver(stream)\n";
print OUTFILE "variable(streamDebug, int)\n";
print OUTFILE "registrar(streamRegistrar)\n";
close (OUTFILE);
$file_name = "streamReferences";
$found_separator = "false";
unless( open( OUTFILE, ">$file_name")) { print "makeStreamReferences.pl couldn't open output file\n";}
foreach ( @ARGV )
$arg = $_;
if($arg eq ":")
$found_separator = "true";
next;
if ($found_separator eq "false")
$out_line = "extern void* ref_" .+ $arg .+ "Interface;\n";
$out_line = "void* p" .+ $arg .+ " = ref_" .+ $arg .+ "Interface;\n";
else
$out_line = "extern void* ref_" .+ $arg .+ "Converter;\n";
$out_line = "void* p" .+ $arg .+ " = ref_" .+ $arg .+ "Converter;\n";
close (OUTFILE);
- RE: Building StreamDevice 2-4 / SynApps / Win32 John Dobbins
- Building StreamDevice 2-4 / SynApps / Win32 John Dobbins
Controls Application Programmer Position at SLAC Ernest L. Williams Jr.
<2010>
2025
2026
Re: Building StreamDevice 2-4 / SynApps / Win32 J. Lewis Muir
<2010>
2025
2026
