1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: Building StreamDevice 2-4 / SynApps / Win32
To: EPICS Tech-Talk <[email protected]>
Date: Fri, 12 Mar 2010 14:53:32 -0500
I have found that the Makefile in the StreamDevice directory srcSynApps has a similar behavior. So I'll apply the same change.
John
From: [email protected] [[email protected]] On Behalf Of John Dobbins [[email protected]]
Sent: Friday, March 12, 2010 2:47 PM
To: EPICS Tech-Talk
Subject: Re: Building StreamDevice 2-4  / SynApps / Win32
First, thanks to everyone for the help with understanding what the problem was in the first place, i.e. that one of the StreamDevice Makefiles depends on certain shell capabilities.
I like the fact that I have been able to build EPICS on Windows with the only the dependencies being GnuMake and Perl. So what I have done is to change the StreamDevice Makefile to call two new Perl scripts. My Makefile for the StreamDevice src directory now looks like:
MAKE_STREAM_DBD_CMD = "../makeStreamDbd.pl"
MAKE_STREAM_REFERENCES_CMD = "../makeStreamReferences.pl"
streamReferences: ../CONFIG_STREAM
        @$(MAKE_STREAM_REFERENCES_CMD) $(BUSSES) : $(FORMATS)
# create stream.dbd from all RECORDS
$(COMMON_DIR)/$(LIBRARY_DEFAULT).dbd: ../CONFIG_STREAM
        @$(MAKE_STREAM_DBD_CMD) $(COMMON_DIR) $(LIBRARY_DEFAULT) $(RECORDS)
I have attached the the Perl scripts I created.
Feel free to suggest improvements that would make this better conform to the standards of the EPICS build system.
John Dobbins
John Dobbins wrote:
> Dear All,
> I am trying to build StreamDevice 2-4 on win32-x86
> I happen to be using the synApps source and the Makefile is show below
> The directories structure is:
> support/
>    asyn
>    std
>    stream
> Everything works fine until I get to stream at which point I get the cryptic error "r was unexpected at this time."
> details:
> make[4]: Entering directory `W:/winDev/epics/R3.14.10/support/stream/2-4/StreamDevice-2-4/src/O.win32-x86'
> make[4]: *** [../O.Common/stream.dbd] Error 255
> make[4]: Leaving directory `W:/winDev/epics/R3.14.10/support/stream/2-4/StreamDevice-2-4/src/O.win32-x86'
> make[3]: *** [install.win32-x86] Error 2
> make[3]: Leaving directory `W:/winDev/epics/R3.14.10/support/stream/2-4/StreamDevice-2-4/src'
> make[2]: *** [src.install] Error 2
> make[2]: Leaving directory `W:/winDev/epics/R3.14.10/support/stream/2-4/StreamDevice-2-4'
> make[1]: *** [StreamDevice-2-4.install] Error 2
> make[1]: Leaving directory `W:/winDev/epics/R3.14.10/support/stream/2-4'
> make: *** [W:/winDev/epics/R3.14.10/support/stream/2-4.install] Error 2
> W:/winDev/epics/R3.14.10/support/stream/2-4/StreamDevice-2-4/src/O.win32-x86' looks like
>   #This Makefile created by makeMakefile.pl
>   all :
>         $(MAKE) -f ../Makefile TOP=../../.. T_A=win32-x86  $@
>   .DEFAULT: force
>   force:  ;
> Advice anyone?
> Thanks,
> John Dobbins
> Lab for Elementary Particle Physics
> Cornell University
> #FILENAME:    Makefile
> #USAGE:               Top Makefile
> #Version:     1.5
> #Modified By: mooney
> #Last Modified:       2009/03/06 21:31:25
> #NOTES- The "SUPPORT_DIRS" order is based on compile time dependencies.
> #     - The user must modify SUPPORT and EPICS_BASE in the
> #       <synApps>/support/configure directory for the local configuration.
> #     - To support multiple configurations, use multiple configure* directories
> #     - Support modules can be shared between configurations only if
> #     dependencies are not violated.  Only the "DIRS" are the target of
> #     gnumake.  If this configuration is using a support module built by
> #     another configuration, then the SUPPORT_DIRS line for that support
> #     module must be commented out (i.e, must begin with a '#').
> # Note the only dependencies that matter in $(<module>)_DEPEND_DIRS are
> # compile-time dependencies.
> TOP = .
> MASTER_FILE = $(TOP)/configure/RELEASE.win32-x86
> include $(TOP)/configure/CONFIG
> ###### 1st Tier Support Modules - Only Depend on EPICS BASE ######
> SUPPORT_DIRS += $(SNCSEQ)
> RELEASE_FILES += $(SNCSEQ)/configure/RELEASE.win32-x86
> SUPPORT_DIRS += $(SSCAN)
> RELEASE_FILES += $(SSCAN)/configure/RELEASE.win32-x86
> SUPPORT_DIRS += $(AUTOSAVE)
> RELEASE_FILES += $(AUTOSAVE)/configure/RELEASE.win32-x86
> ###### 2nd Tier Support Modules - Only Depend on 1st Tier ########
> SUPPORT_DIRS += $(ASYN)
> RELEASE_FILES += $(ASYN)/configure/RELEASE.win32-x86
> $(ASYN)_DEPEND_DIRS = $(SNCSEQ)
> SUPPORT_DIRS += $(CALC)
> RELEASE_FILES += $(CALC)/configure/RELEASE.win32-x86
> $(CALC)_DEPEND_DIRS = $(SSCAN)
> ################### 3rd Tier Support Modules #####################
> SUPPORT_DIRS += $(BUSY)
> RELEASE_FILES += $(BUSY)/configure/RELEASE.win32-x86
> $(BUSY)_DEPEND_DIRS = $(ASYN)
> SUPPORT_DIRS += $(STD)
> RELEASE_FILES += $(STD)/configure/RELEASE.win32-x86
> $(STD)_DEPEND_DIRS = $(ASYN)
> SUPPORT_DIRS += $(STREAM)
> RELEASE_FILES += $(STREAM)/configure/RELEASE.win32-x86
> $(STREAM)_DEPEND_DIRS = $(ASYN) $(CALC) $(SSCAN)
> ################### 4th Tier Support Modules #####################
> #SUPPORT_DIRS += $(MCA)
> #RELEASE_FILES += $(MCA)/configure/RELEASE.win32-x86
> #$(MCA)_DEPEND_DIRS = $(ASYN) $(STD)
> ################### 5th Tier Support Modules #####################
> #SUPPORT_DIRS += $(AREA_DETECTOR)
> #RELEASE_FILES += $(AREA_DETECTOR)/configure/RELEASE.win32-x86
> #$(AREA_DETECTOR)_DEPEND_DIRS = $(ASYN) $(SSCAN) $(MCA)
> ################### End of Support-Modules #####################
> DIRS = $(SUPPORT_DIRS)
> ################### User Modules #####################
> ACTIONS += uninstall realuninstall distclean cvsclean
> include $(EPICS_BASE)/configure/RULES_TOP
> release:
>       echo SUPPORT=$(SUPPORT)
>       echo ' '
>       echo EPICS_BASE=$(EPICS_BASE)
>       echo ' '
>       echo MASTER_FILE=$(MASTER_FILE)
>       echo ' '
>       echo DIRS=$(DIRS)
>       echo ' '
>       echo RELEASE_FILES=$(RELEASE_FILES)
>       echo ' '
>       $(PERL) $(TOP)/configure/makeReleaseConsistent.pl $(SUPPORT) $(EPICS_BASE) $(MASTER_FILE) $(RELEASE_FILES)
Building StreamDevice 2-4 / SynApps / Win32 John Dobbins
Re: Building StreamDevice 2-4 / SynApps / Win32 John Dobbins
Prev: Re: Building StreamDevice 2-4 / SynApps / Win32 John Dobbins
Next: INP field length Steve Kinder
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: IS SDDS not avaible? 汪启胜
