1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: INP field length
To: [email protected]
Date: Mon, 15 Mar 2010 09:30:43 -0600
Hi Steve,
On Monday 15 March 2010 04:45:15 Steve Kinder wrote:
> Is there any length restriction on an INP field, before or after the
> expansion of any macros it may contain?
Unlike many places inside the IOC, there is no built-in length limitation to
the value that can be placed in a link field using dbLoadRecords(), which
means that the @parm part of a hardware link address can be as long as you
like.
Of course if you want to read or update the field through CA there is a 40
character limit to the string you can pass as a DBR_STRING, and with the new
array-of-chars support in 3.14.11 using the @ field modifier I believe CA will
still limit you to passing at most 72 characters to/from a link field.
HTH,
- Andrew
The best FOSS code is written to be read by other humans -- Harald Welte
Re: INP field length Steve Kinder
Prev: RE: LabVIEW EPICS I/O Server Pawel Kowalski - BiRa Systems Inc.
Next: Re: INP field length Steve Kinder
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: INP field length Steve Kinder
