Hi Andrew
Thanks for the reply, that was what I thought. But just to clarify my
specific case. I'm using StreamDevice2 and have a INP field as follows with
template/substitution.
field(INP, "@TEST.protocol getCs($(DEVICE),C2,C3,C4) $(port) 0")
If I understand things correctly, whatever the length of DEVICE and port I
shouldn't encounter problems. Well due to the length of the field at least.
Regards
Steve
----- Original Message -----
To: <[email protected]>
Cc: "Steve Kinder" <[email protected]>
Sent: Monday, March 15, 2010 3:30 PM
Subject: Re: INP field length
Hi Steve,
On Monday 15 March 2010 04:45:15 Steve Kinder wrote:
Is there any length restriction on an INP field, before or after the
expansion of any macros it may contain?
Unlike many places inside the IOC, there is no built-in length limitation
to
the value that can be placed in a link field using dbLoadRecords(), which
means that the @parm part of a hardware link address can be as long as you
like.
Of course if you want to read or update the field through CA there is a 40
character limit to the string you can pass as a DBR_STRING, and with the
new
array-of-chars support in 3.14.11 using the @ field modifier I believe CA
will
still limit you to passing at most 72 characters to/from a link field.
HTH,
- Andrew
The best FOSS code is written to be read by other humans -- Harald Welte
- Re: INP field length Andrew Johnson
- Re: INP field length Dirk Zimoch
- INP field length Steve Kinder
<2010>
2025
2026
<2010>
2025
2026
ANJ, 02 Sep 2010 |
Home
News
About
Talk
Base
Modules
Extensions
Distributions
Download
Documents
Links
Licensing
