Eric,
> Was that to the iocsh or to the vxWorks shell? The latter would need
quotes around the task name.
> I suspect that you were just lucky to get the task list twice and not
to get an access fault!
No, I did it correctly. Here's the proof.
ioc13bma> iocsh
epics> thread -5 taskwd
NAME ENTRY TID PRI STATUS PC SP ERRNO
DELAY
tExcTask excTask 1dfd3d0 0 PEND 1c1750 1dfd2e0
30065 0
tLogTask logTask 1dfaa48 0 PEND 1c1750 1dfa968
0 0
CAC-repeate1ba03cc 1342cc0 189 PEND 15f8ec 1342a78
16 0
cpuUsageTas19675a8 150f4d0 255 READY 10e698 150f3f8
0 0
DELAY
30065 0
0 0
16 0
cpuUsageTas19675a8 150f4d0 255 PEND 15f8ec 150f430
0 0
So it just prints the entire task list twice.
If I spell the task name wrong I get a different output:
*** argument 2 (taskw) is not a valid thread name ***
-----Original Message-----
Sent: Monday, March 29, 2010 1:16 PM
To: Mark Rivers
Cc: Andrew Johnson; EPICS tech-talk
Subject: Re: Missing iocsh command?
On Mar 29, 2010, at 10:51 AM, Mark Rivers wrote:
> Hi Eric,
> Thanks for the information. It seems like renaming "thread" to
> epicsThreadShow would be more consistent.
I agree.
Andrew, can you please make the one-line change to
iocsh/libComRegister.c:
--- ../../iocsh/libComRegister.c 2009-02-24 12:10:57.000000000
-0800
+++ /tmp/blah 2010-03-29 11:09:00.000000000 -0700
@@ -204,7 +204,7 @@
/* thread (thread information) */
static const iocshArg threadArg0 = { "[-level] [thread ...]",
iocshArgArgv};
static const iocshArg * const threadArgs[1] = { &threadArg0 };
-static const iocshFuncDef threadFuncDef = {"thread",1,threadArgs};
+static const iocshFuncDef threadFuncDef =
{"epicsThreadShow",1,threadArgs};
static void threadCallFunc(const iocshArgBuf *args)
int i = 1;
and the corresponding change to the app dev guide 'show' command?
> More importantly, the "-level" argument does not seem to provide any
> additional information, at least on Linux or vxWorks. It would be
very
> helpful if higher levels could print additional information like stack
> usage, etc.
Yep, none of the operating-system specific implementations of
epicsThreadShow appear to do anything with the 'level' argument.
> On vxWorks the following command:
> thread -5 taskwd
> does not restrict its output to the taskwd thread. In fact it just
> prints out the entire thread list twice.
quotes around the task name. I suspect that you were just lucky to get
the task list twice and not to get an access fault!
Should the epicsThreadShowAll command just go away? It's function is
identical to that of epicsThreadShow with no thread-name (or thread-id)
arguments.
Eric Norum
[email protected]
- Missing iocsh command? Mark Rivers
- Re: Missing iocsh command? Eric Norum
- RE: Missing iocsh command? Mark Rivers
Matsusada R4K Series Wesley Moore
<2010>
2025
2026
Solaris version and edm John William Sinclair
<2010>
2025
2026
