1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: command line tool to list all field values of a Record ?
Date: Mon, 12 Apr 2010 16:26:08 -0400
Andrew Johnson wrote:
On Monday 12 April 2010 14:53:09 Ralph Lange wrote:
Through Channel Access: Not that I know.
John Maclean wrote a Perl script called capr that does this to some extent, but it's rather old now (2003), relies on the command-line program caget (but not the one that comes with Base), and as you would expect can only display those fields of a record that are accessible through CA. It has to parse a DBD file to work out what fields each record type has, but it has a default path and will also read an environment variable so you don't have to specify the path every time. I can provide a copy if anyone is interested, but it will probably need some effort to get it working at another site.
I thought Kay Kasemir had included a tool like this into CSS at one point, but I might be wrong about that.
Andrew,
I would appreciate it if you could send capr.
Yes, CSS includes PVTree which is similar.
John
Re: command line tool to list all field values of a Record ? Kasemir, Kay
command line tool to list all field values of a Record ? John Dobbins
Re: command line tool to list all field values of a Record ? Ralph Lange
Re: command line tool to list all field values of a Record ? Andrew Johnson
Prev: Re: command line tool to list all field values of a Record ? Andrew Johnson
Next: Re: command line tool to list all field values of a Record ? Tim Mooney
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Re: command line tool to list all field values of a Record ? Kasemir, Kay
