1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: command line tool to list all field values of a Record ?
To: "'Kasemir, Kay'" <[email protected]>, "'John Dobbins'" <[email protected]>
Cc: [email protected]
Date: Mon, 12 Apr 2010 17:00:18 -0500
Hi Kay,
As an addendum to your mention of IRMIS-type data on EPICS PVs, the IRMIS 2 Global Search Tool (GST) provides information on a PV’s optional alias names (if alias names have been defined) and links to more information about that PV’s IOC and AOIs (please see picture below of IRMIS 2 GST).
Debby
-----Original Message-----
From: [email protected] [mailto:[email protected]] On Behalf Of Kasemir, Kay
Sent: Monday, April 12, 2010 4:37 PM
To: John Dobbins; Andrew Johnson
Subject: Re: command line tool to list all field values of a Record ?
Hi:
As mentioned, Channel Access doesn't tell you what fields a record might
have. You have to parse the DBD file that your IOC loaded.
> Yes, CSS includes PVTree which is similar.
The CSS PV Tree,
http://sourceforge.net/apps/trac/cs-studio/wiki/EPICSPVTree, uses Channel
Access to read .RTYP, then uses a configurable table to read more fields
depending on the record type, for example INPA, INPB, INPC, ... for calc
records, and tries to figure out if those in turn contain what looks like
another record name, which it then reads recursively.
In addition we have a "PV Fields" tool for CSS, see
http://sourceforge.net/apps/trac/cs-studio/wiki/PVFieldsViewer ,
that displays all the configured fields of a record,
Value in the original DB file as well as current value,
based on IRMIS-type data in the RDB.
Kay
Re: command line tool to list all field values of a Record ? John Dobbins
Re: command line tool to list all field values of a Record ? Kasemir, Kay
Prev: Re: command line tool to list all field values of a Record ? Kasemir, Kay
Next: asyn R4-13 available Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Re: command line tool to list all field values of a Record ? Tim Mooney
