I believe this was solved with entry 334 in Mantis. R3.14.11 was the
first release with the fix. The problem occurred when I connected to PVs
from 2 or more IOCs and it happened when I was exiting the program. It
only happened rarely, but enough to be a big problem for us.
P.S. How can we search launchpad for Mantis bug numbers?
[email protected] wrote:
Hi Ralph, Xiaoqiang,
This isn't just HP-UX. If I do:
for (( i=0; i<100; i++ )) ; do caget CS-CS-MSTAT-01:MODE; echo $?; done
On RHEL5/R3.14.8.2 this generates the message "epicsThreadOnceOsd
epicsMutexLock failed." (usually, but not always, with exit status 255)
about every 20 caget's.
If I do the same thing on RHEL5/R3.14.11 it doesn't seem to happen (at
least not in 500 tries).
Whatever it is, it seems to have got better with R3.14.11 and so maybe
that's what Xiaoqiang should try. If someone still wants me to generate
a stack trace I can, but maybe we can close it with a message.
Cheers,
Nick Rees
Principal Software Engineer Phone: +44 (0)1235-778430
Diamond Light Source Fax: +44 (0)1235-446713
-----Original Message-----
[mailto:[email protected]] On Behalf Of Ralph Lange
Sent: 16 April 2010 16:22
To: Wang Xiaoqiang
Cc: EPICS Tech Talk
Subject: Re: epicsThreadOnceOsd epicsMutexLock failed
Hello Xiaoqiang,
Please note that the EPICS Base bug tracker has been moved to the new
EPICS Base location on Lauchpad, this bug is now:
https://bugs.launchpad.net/epics-base/+bug/541249
The old Mantis tracker is still on-line for reference, but it
is *not*
updated anymore.
The bug is suspended, because Jeff was asking for a stack trace which
was never provided.
The bug is about erroneous behavior experienced on the HP-UX
operating
system.
Support for HP-UX has been dropped with EPICS release 3.14.9, so this
bug will most probably never be fixed.
If you experience the error on a different version of EPICS and a
different operating system, please check on Launchpad if it has been
reported. If not, you are encouraged to file a new bug report.
Thanks a lot,
Ralph
On Fri 16 Apr 2010 10:08:53 Wang Xiaoqiang wrote:
When CA client exit, sometimes it spills out "epicsThreadOnceOsd
epicsMutexLock failed" message. It has been reported since
3.14.7 and
has an entry 207 in Mantis. The status is labeled as
"suspended". Does
it mean it is hopeless to be solved?
http://www.aps.anl.gov/epics/mantis/view_bug_page.php?f_id=207
In normal cases it is harmless since the program is anyway exiting.
However it exits with code 255. If it is run as a
subprocess, this will
cause the caller think exit code other than 0 is wrong and stop
execution. In such case one cannot ignore the exit code, which would
ignore other possible exceptions.
Thanks and nice weekend.
Dr. Xiaoqiang Wang
Paul Scherrer Institut, WBGB/010
5232 Villigen PSI, Switzerland
- Re: epicsThreadOnceOsd epicsMutexLock failed Ralph Lange
- epicsThreadOnceOsd epicsMutexLock failed Wang Xiaoqiang
- RE: epicsThreadOnceOsd epicsMutexLock failed nick.rees
<2010>
2025
2026
<2010>
2025
2026
ANJ, 02 Sep 2010 |
Home
News
About
Talk
Base
Modules
Extensions
Distributions
Download
Documents
Links
Licensing
