1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: epicsThreadOnceOsd epicsMutexLock failed
To: <[email protected]>, <[email protected]>, <[email protected]>
Cc: [email protected]
Date: Fri, 16 Apr 2010 21:28:07 +0200
Thanks all!
Nick said it right. That is exactly the problem.
Unfortunately we, as conservatives, are still using EPICS 3.14.8 on Linux.
I hope we can get an update in not far future.
Nice weekend,
Xiaoqiang
Sent: Fri 4/16/2010 5:52 PM
To: [email protected]; Wang Xiaoqiang
Hi Ralph, Xiaoqiang,
This isn't just HP-UX. If I do:
for (( i=0; i<100; i++ )) ; do caget CS-CS-MSTAT-01:MODE; echo $?; done
On RHEL5/R3.14.8.2 this generates the message "epicsThreadOnceOsd
epicsMutexLock failed." (usually, but not always, with exit status 255)
about every 20 caget's.
If I do the same thing on RHEL5/R3.14.11 it doesn't seem to happen (at
least not in 500 tries).
Whatever it is, it seems to have got better with R3.14.11 and so maybe
that's what Xiaoqiang should try. If someone still wants me to generate
a stack trace I can, but maybe we can close it with a message.
Cheers,
Nick Rees
Principal Software Engineer           Phone: +44 (0)1235-778430
Diamond Light Source                  Fax:   +44 (0)1235-446713
> -----Original Message-----
> From: [email protected]
> [mailto:[email protected]] On Behalf Of Ralph Lange
> Sent: 16 April 2010 16:22
> To: Wang Xiaoqiang
> Cc: EPICS Tech Talk
> Subject: Re: epicsThreadOnceOsd epicsMutexLock failed
> Hello Xiaoqiang,
> Please note that the EPICS Base bug tracker has been moved to the new
> EPICS Base location on Lauchpad, this bug is now:
>    https://bugs.launchpad.net/epics-base/+bug/541249
> The old Mantis tracker is still on-line for reference, but it
> is *not*
> updated anymore.
> The bug is suspended, because Jeff was asking for a stack trace which
> was never provided.
> The bug is about erroneous behavior experienced on the HP-UX
> operating
> system.
> Support for HP-UX has been dropped with EPICS release 3.14.9, so this
> bug will most probably never be fixed.
> If you experience the error on a different version of EPICS and a
> different operating system, please check on Launchpad if it has been
> reported. If not, you are encouraged to file a new bug report.
> Thanks a lot,
> Ralph
> On Fri 16 Apr 2010 10:08:53 Wang Xiaoqiang wrote:
> > Hi,
> > When CA client exit, sometimes it spills out "epicsThreadOnceOsd
> > epicsMutexLock failed" message. It has been reported since
> 3.14.7 and
> > has an entry 207 in Mantis. The status is labeled as
> "suspended". Does
> > it mean it is hopeless to be solved?
> > http://www.aps.anl.gov/epics/mantis/view_bug_page.php?f_id=207
> > In normal cases it is harmless since the program is anyway exiting.
> > However it exits with code 255. If it is run as a
> subprocess, this will
> > cause the caller think exit code other than 0 is wrong and stop
> > execution. In such case one cannot ignore the exit code, which would
> > ignore other possible exceptions.
> > Thanks and nice weekend.
> > Dr. Xiaoqiang Wang
> > Paul Scherrer Institut, WBGB/010
> > 5232 Villigen PSI, Switzerland
epicsThreadOnceOsd epicsMutexLock failed Wang Xiaoqiang
Re: epicsThreadOnceOsd epicsMutexLock failed Ralph Lange
RE: epicsThreadOnceOsd epicsMutexLock failed nick.rees
Prev: EPICS Training Course in UK, June 7-11th Philip Taylor
Next: RE: Labview and EPICS on Linux Zhukov, Alexander P.
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: epicsThreadOnceOsd epicsMutexLock failed Ralph Lange
Next: EPICS Training Course in UK, June 7-11th Philip Taylor
