You will... count on it.
Pawel Kowalski - BiRa Systems Inc. wrote:
Thanks Andrew, when I commented those lines out it compiled fine. I hope I
don't run in to any issues in the future because of this. Thanks again.
Pawel Kowalski
BiRa Systems Inc.
www.bira.com
Phone: 505-881-8887
Fax: 505-888-0651
Address: 2410 Midtown PL NE
STE A
Albuquerque NM 87107 USA
-----Original Message-----
Sent: Thursday, April 29, 2010 1:53 PM
To: [email protected]
Cc: Mark Rivers; Pawel Kowalski - BiRa Systems Inc.
Subject: Re: Problem Building SNC/SEQ Module
On Thursday 29 April 2010 14:41:18 Mark Rivers wrote:
A little more investigation shows that in snc/Makefile there is the
following:
# Lex library
SYS_PROD_LIBS_WIN32 += -nil-
SYS_PROD_LIBS_cygwin32 += -nil-
SYS_PROD_LIBS_Linux += fl
SYS_PROD_LIBS_DEFAULT += l
So Linux does require the Lex library. On Fedora you could install this
with "yum install flex".
I really don't think that the flex library should be needed since Base
includes its own copy of flex. I would suggest commenting out *all* of the
lines mark listed above from the Makefile, I just tried it and it worked for
me.
- Andrew
- Problem Building SNC/SEQ Module Pawel Kowalski - BiRa Systems Inc.
- RE: Problem Building SNC/SEQ Module Mark Rivers
- Re: Problem Building SNC/SEQ Module Andrew Johnson
- RE: Problem Building SNC/SEQ Module Pawel Kowalski - BiRa Systems Inc.
Dump record fields into a text file emmanuel_mayssat
<2010>
2025
2026
<2010>
2025
2026
