Hi Andrew,
Please look an attached python script.
I use this script to build openmotif2.2.3 library on MacOSX 10.6(Snow
Leopard).
I create 4 sub directories, build-ppc, build-i386, build-x86_64 and
build-universl in open motif directory, then put mk_univesl.py in the
build-universl directory.
In buil-universl directory, start python and in the python interpreter,run :
>>from mk_universl import *
>>setup_configure()
>>run_make()
>>main()
If everything goes well, you will have universal binary under
build-x86_64. Then run "make install" (or "sudo make install") in
./build-x86_64 directory.
You may need to run
>>run_make()
>>main()
repeatedly to build universal binary library.
I wrote this script just for me, so you might encounter rough edge.
Anyway, I build openmotif library for MacOSX 10.6 with this script and
medm with it.
> EPICS compiles with i386 (see -arch i386 above)
Set EPICS_HOST_ARCH=darwin-ppcx86 then EPICS make system creates
regards,
Noboru Yamamoto
J-PARC control group
KEK,JAPAN
(10/06/23 9:28), Andrew Wagner wrote:
> Thanks for the warning Ralph,
> I think I'm almost there. I discovered that the openmotif Makefile puts your libs and headers exactly where they should be to be broadly accessible. /usr/X11R6/lib and /usr/X11R6/include . I can now almost compile MEDM. The problem is:
> make -C O.darwin-x86 -f ../Makefile TOP=../../../.. T_A=darwin-x86 install
> /usr/bin/c++ -o medm -L/Users/andrewwagner/EPICS/base-3-14-11/lib/darwin-x86 -L/Users/andrewwagner/EPICS/extensions/lib/darwin-x86 -L/usr/X11R6/lib -arch i386 (etc ....)
> ld: warning: in /usr/X11R6/lib/libXm.dylib, file was built for unsupported file format which is not the architecture being linked (i386)
> Undefined symbols:
> This is due to the fact that openmotif compiles with default gcc (i.e. i686-apple-darwin10-gcc-4.2.1) but EPICS compiles with i386 (see -arch i386 above). How do I hack the EPICS Makefiles to build something other than i386? I believe that if all -arch options are unset then it should use the default 64 bit compiler. How do I do this? Alternatively I could recompile openmotif in i386.
> Cheers,
> Andrew
> On Jun 22, 2010, at 1:40 PM, Ralph Lange wrote:
>> Andrew,
>> did you check the results of searching the tech-talk archives [1] for "openmotif"?
>> Have a look and then reconsider how much you want to get involved.....
>> Cheers,
>> Ralph
>> [1] http://www.aps.anl.gov/epics/tech-talk/index.php
>> On Tue 22 Jun 2010 16:30:11 Andrew Wagner wrote:
>>> Thanks Eric,
>>> Unfortunately I ran into the pitfall of attempting to install openmotif form source via http://www.openmotif.org/ . I was able to compile openmotif and install the programs but unfortunately its Makefile and the EPICS/extensions Makefile are incompatible. They seem to expect libraries to be built with different rules and put in different locations. The .h files medm needed where in openmotif-2.3.0/lib not /include and a library file libXm.a appears to never be built with the Makefile from openmotif.org<http://openmotif.org> . I get the error:
>>> No rule to make target `/Users/andrewwagner/OpenMotif/openmotif-2.3.0/lib/libXm.a'
>>> Does anyone have experience installing openmotif from source? There must be a way to do this on a Linux box. For the time being I can just delete openmotif and reinstall from Darwin ports.
>>> Cheers,
>>> Andrew
>>> On Jun 22, 2010, at 9:16 AM, Eric Norum wrote:
>>>> I have the fink openmotif3 2.2.4-4 package installed on my OS X machine. Seems to work well with MEDM, EDM, StripTool and SDDSplot.
>>>> MEDM is an extension:
>>>> Download the extensions configuration files from EPICS Extensions Config Files<http://www.aps.anl.gov/epics/extensions/configure/index.php>
>>>> Unpack the config file tarball. cd to the extensions directory created by unpacking the tarball. This directory will be referred to as the extensions<TOP> from now on
>>>> Edit the configure/RELEASE file top refer to where you have EPICS base installed.
>>>> Edit the configure/os/CONFIG_SITE.darwin-x86.darwin-x86 file and set up the correct references to your X11 and Motif packages.
>>>> cd to the<TOP> directory and run make
>>>> Now to download and build an extension -- medm in this case:
>>>> Download the medm tarball: MEDM 3.1.4<http://www.aps.anl.gov/epics/download/extensions/medm3_1_4.tar.gz>
>>>> cd to the<TOP>/src directory and unpack the medm tarball
>>>> cd to the<TOP>/src/medm directory and run make
>>>> On Jun 21, 2010, at 6:06 PM, Andrew Wagner wrote:
>>>>> Hey guys,
>>>>> I'm new to EPICS and have compiled both EPICS base and Asyn successfully on my OS X 10.6.3 MacBook Pro. It seems that much of the driver support includes pre-made MEDM screens. Is there a good how-to manual for installing MEDM on OS X (or any os)? I've searched tech-talk and there definitely seem to be some pitfalls. For instance Motif 2.30 should be used instead of 2.32 to avoid some odd behavior. Thanks very much for the help.
>>>>> Andrew Wagner
>>>> Eric Norum
>>>> [email protected]<mailto:[email protected]>
#!/bin/env python
these libraries should also build as universal binaries
ld warning: in /opt/local/lib/libiconv.dylib, file is not of required architecture
ld warning: in /opt/local/lib/libz.dylib, file is not of required architecture
ld warning: in /opt/local/lib/libexpat.dylib, file is not of required architecture
import os
import re
ObjectFilePattern=re.compile(".*((Mach-O)|(ar archive)).*")
def main():
for root, dirs, files in os.walk('../build-x86_64'):
for fl in files:
if (isObjectFile(root,fl)):
mkUniversal(root,fl)
def test(path='../build-x86_64'):
for root, dirs, files in os.walk(path):
for fl in files:
pass
def test_all():
test("../build-ppc")
test("../build-i386")
test("../build-x86_64")
def isObjectFile(root,fl):
cmd="file %s"%(os.path.join(root,fl))
o=os.popen(cmd)
out=o.readlines()
ret=ObjectFilePattern.match(out[0])
if (ret):
print root,fl, out
return ret
def runcmd(cmd):
print cmd
os.system(cmd)
def mkUniversal(root,fl):
bn=os.path.basename(fl)
path=root.split(os.sep)
path[1]="build-i386"
x86fn=os.path.join(os.path.join(*path),fl)
path[1]="build-x86_64"
x86_64fn=os.path.join(os.path.join(*path),fl)
path[1]="build-ppc"
ppcfn=os.path.join(os.path.join(*path),fl)
runcmd("/usr/bin/lipo -create %s %s %s -output %s"%(ppcfn, x86fn, x86_64fn, bn))
runcmd('mv -f %s %s'%(bn,x86_64fn))
- Re: MEDM installation instructions Andrew Wagner
- MEDM installation instructions Andrew Wagner
- Re: MEDM installation instructions Eric Norum
- Re: MEDM installation instructions Ralph Lange
<2010>
2025
2026
<2010>
2025
2026
