1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: MEDM installation instructions
To: Noboru Yamamoto <[email protected]>
Date: Wed, 23 Jun 2010 00:53:01 -0700
Thanks again everyone for the help,
I finally succeeded in compiling openmotif and medm. The problem was that openmotif is by default compiled in 64 bit architecture in OS X 10.6 . The darwin-x86 host arch defined in EPICS is 32 bit. Since medm compiles with options inherited from EPICS there will arise a conflict when medm is linked. The solution that I found was to modify CONFIG_SITE.Common.darwin-x86 to define ARCH_CLASS=x86_64 and recompile EPICS. I now have consistent 64 bit architecture and the entire compilation worked start to finish. This solution works for me since I don't foresee the need to use or export binaries to an old ppc. If this is the case for you I suggest looking at Noboru's python script for an alternate solution.
Cheers,
Andrew
On Jun 22, 2010, at 7:55 PM, Noboru Yamamoto wrote:
> Hi Andrew,
> Please look an attached python script.
> I use this script to build openmotif2.2.3 library on MacOSX 10.6(Snow
> Leopard).
> I create 4 sub directories, build-ppc, build-i386, build-x86_64 and
> build-universl in open motif directory, then put mk_univesl.py in the
> build-universl directory.
> In buil-universl directory, start python and in the python interpreter,run :
>>> from mk_universl import *
>>> setup_configure()
>>> run_make()
>>> main()
> If everything goes well, you will have universal binary under
> build-x86_64. Then run "make install" (or "sudo make install") in
> ./build-x86_64 directory.
> You may need to run
>>> run_make()
>>> main()
> repeatedly to build universal binary library.
> I wrote this script just for me, so you might encounter rough edge.
> Anyway, I build openmotif library for MacOSX 10.6 with this script and
> medm with it.
>> EPICS compiles with i386 (see -arch i386 above)
> Set EPICS_HOST_ARCH=darwin-ppcx86 then EPICS make system creates
> regards,
> Noboru Yamamoto
> J-PARC control group
> KEK,JAPAN
> (10/06/23 9:28), Andrew Wagner wrote:
>> Thanks for the warning Ralph,
>> I think I'm almost there. I discovered that the openmotif Makefile puts your libs and headers exactly where they should be to be broadly accessible. /usr/X11R6/lib and /usr/X11R6/include . I can now almost compile MEDM. The problem is:
>> make -C O.darwin-x86 -f ../Makefile TOP=../../../.. T_A=darwin-x86 install
>> /usr/bin/c++ -o medm  -L/Users/andrewwagner/EPICS/base-3-14-11/lib/darwin-x86 -L/Users/andrewwagner/EPICS/extensions/lib/darwin-x86 -L/usr/X11R6/lib       -arch i386     (etc ....)
>> ld: warning: in /usr/X11R6/lib/libXm.dylib, file was built for unsupported file format which is not the architecture being linked (i386)
>> Undefined symbols:
>> This is due to the fact that openmotif compiles with default gcc (i.e. i686-apple-darwin10-gcc-4.2.1) but EPICS compiles with i386 (see -arch i386 above). How do I hack the EPICS Makefiles to build something other than i386? I believe that if all -arch options are unset then it should use the default 64 bit compiler. How do I do this? Alternatively I could recompile openmotif in i386.
>> Cheers,
>> Andrew
>> On Jun 22, 2010, at 1:40 PM, Ralph Lange wrote:
>>> Andrew,
>>> did you check the results of searching the tech-talk archives [1] for "openmotif"?
>>> Have a look and then reconsider how much you want to get involved.....
>>> Cheers,
>>> Ralph
>>> [1] http://www.aps.anl.gov/epics/tech-talk/index.php
>>> On Tue 22 Jun 2010 16:30:11 Andrew Wagner wrote:
>>>> Thanks Eric,
>>>> Unfortunately I ran into the pitfall of attempting to install openmotif form source via http://www.openmotif.org/ . I was able to compile openmotif and install the programs but unfortunately its Makefile and the EPICS/extensions Makefile are incompatible. They seem to expect libraries to be built with different rules and put in different locations. The .h files medm needed where in openmotif-2.3.0/lib not /include and a library file libXm.a appears to never be built with the Makefile from openmotif.org<http://openmotif.org>  . I get the error:
>>>> No rule to make target `/Users/andrewwagner/OpenMotif/openmotif-2.3.0/lib/libXm.a'
>>>> Does anyone have experience installing openmotif from source? There must be a way to do this on a Linux box. For the time being I can just delete openmotif and reinstall from Darwin ports.
>>>> Cheers,
>>>> Andrew
>>>> On Jun 22, 2010, at 9:16 AM, Eric Norum wrote:
>>>>> I have the fink openmotif3 2.2.4-4 package installed on my OS X machine.  Seems to work well with MEDM, EDM, StripTool and SDDSplot.
>>>>> MEDM is an extension:
>>>>> Download  the extensions configuration files from EPICS Extensions Config Files<http://www.aps.anl.gov/epics/extensions/configure/index.php>
>>>>> Unpack the config file tarball. cd to the extensions  directory created by unpacking the tarball.  This directory will be referred to as the extensions<TOP>  from now on
>>>>> Edit the configure/RELEASE file top refer to where you have EPICS base installed.
>>>>> Edit the configure/os/CONFIG_SITE.darwin-x86.darwin-x86 file and set up the correct references to your X11 and Motif packages.
>>>>> cd to the<TOP>  directory and run make
>>>>> Now to download and build an extension -- medm in this case:
>>>>> Download the medm tarball:  MEDM 3.1.4<http://www.aps.anl.gov/epics/download/extensions/medm3_1_4.tar.gz>
>>>>> cd to the<TOP>/src directory and unpack the medm tarball
>>>>> cd to the<TOP>/src/medm directory and run make
>>>>> On Jun 21, 2010, at 6:06 PM, Andrew Wagner wrote:
>>>>>> Hey guys,
>>>>>> I'm new to EPICS and have compiled both EPICS base and Asyn successfully on my OS X 10.6.3 MacBook Pro. It seems that much of the driver support includes pre-made MEDM screens. Is there a good how-to manual for installing MEDM on OS X (or any os)? I've searched tech-talk and there definitely seem to be some pitfalls. For instance Motif 2.30 should be used instead of 2.32 to avoid some odd behavior. Thanks very much for the help.
>>>>>> Andrew Wagner
>>>>> Eric Norum
>>>>> [email protected]<mailto:[email protected]>
> <mk_universl.py>
MEDM installation instructions Andrew Wagner
Re: MEDM installation instructions Eric Norum
Re: MEDM installation instructions Andrew Wagner
Re: MEDM installation instructions Ralph Lange
Re: MEDM installation instructions Noboru Yamamoto
Prev: Re: MEDM installation instructions Noboru Yamamoto
Next: Re: No monitor refresh [SOLVED] Hinko Kocevar
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Re: MEDM installation instructions Pelaia II, Tom
