1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Tekronix and R&S drivers
To: Andrew Wagner <[email protected]>
Cc: [email protected]
Date: Thu, 08 Jul 2010 16:51:33 -0500
Andrew,
Tektronix would never give us any information on the VXI-11. When I first developed this support, it was for GPIB, but then Eric Norum developed ASYN support for vxi-11 which allowed us to network these scopes. Maybe Eric could shed more light on this.
The programmers manual from Tektronix website is what I used for both 3000 & 5000 scopes.
There should be an example from the download which shows how to setup the vxi11 for each scope in the st.cmd file. Just a simple "vxi11Configure" command for each scope being defined.
Nick
On 7/8/2010 3:59 PM, Andrew Wagner wrote:
Thanks Nicholas,
The programmers manual for the MSO 4000 can be downloaded from the Tektronix website. Is there more documentation out there for communicating with Tektronix equipment. For instance, the programers manual tells the reader nothing about vxi-11. Your code is the best documentation so far.
Cheers,
Andrew
On Jul 8, 2010, at 8:18 AM, Nicholas P. DiMonte wrote:
Andrew,
The TDS3000 support does not support the digital channels of MSO4000 series, but may work with the analog inputs with some minor changes to the device support. The TDS3000 also includes the TDS5000 series, so you can use that as a template to develop the analog side of the MSO4000 scopes. It looks like the MSO4000 follows most of the basic commands used in both the 3000/5000 series. The digital inputs I'm sure can be implemented, but you may want to create a whole new support for MSO4000 series, which the TDS3000 support would be a good starting point.
Nick DiMonte
APS, Argonne
On 7/8/2010 1:26 AM, Andrew Wagner wrote:
Hey everyone,
Has anyone written driver/device support for the the Tektronix MSO 4000 series of oscilloscopes? My model is specifically the 4054. Is this at all similar to the TDS 3000 for which support exists? I'm also interested in support for the Rhode&Schwarz ZVL Network analyzer. How generic are the commands that Tektronix, for instance, uses? Has someone written a base class with the common commands supported?
Cheers,
Andrew Wagner
Tekronix and R&S drivers Andrew Wagner
Re: Tekronix and R&S drivers Nicholas P. DiMonte
Re: Tekronix and R&S drivers Andrew Wagner
Prev: Re: Tekronix and R&S drivers Andrew Wagner
Next: Re: Tekronix and R&S drivers Eric Norum
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
