1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: HTML Device Driver
To: [email protected]
Date: Wed, 28 Jul 2010 11:28:40 -0500
I suggest something such as "tidy" (http://tidy.sourceforge.net/) is used to clean up the HTML or XML input to make it valid XML. Then use XPATH to pick the desired items from the cleaned up XML.
On 7/28/10 11:14 AM, J. Lewis Muir wrote:
On 7/28/10 10:33 AM, David Dudley wrote:
Here’s a new one for you (Got Ralph and Michael going about how to do
it, anyway ;-)
Almost all of the PLC equipment we’re going to be using on NSLS/2 is
connected on Ethernet.
It is common practice in the communications modules now, to integrate an
embedded WEB server into the device.  Both the Siemens and Rockwell
hardware we’re going to use have that capability, as well as most of the
new generation of instrumentation.
Does anyone have knowledge of an EPICS device driver that is capable of
reading and interpreting a WEB page or XML page?  Seems that this would
be the most universal way to read data from all this differing
equipment, if such a driver was available.
David Dudley
Hi, David.
Are you asking about a generic EPICS device driver for communicating
with devices via HTTP and capable of interpreting HTML or XML, or are
you asking about existing drivers that do this for a particular device?
I've written two drivers that communicate w/ the device via HTTP and
then extract the needed information from an HTML response:
   http://www.imca.aps.anl.gov/~jlmuir/sw/dli-epcr.html
   http://www.imca.aps.anl.gov/~jlmuir/sw/websensor-em01b.html
These drivers use asyn but have hacks to deal w/ the connection getting
closed after each request which asyn did not handle well before asyn
4-13.  According to the asyn 4-13 release notes, new behavior has been
added to handle this by specifying "http" as the protocol in
drvAsynIPPortConfigure.  I haven't tried it yet.
Certainly something generic could be written to make it easy to
construct the HTTP request, handle any authentication, and handle the
response.  This might provide something like the httplib module in Python.
I think it would get more difficult if you wanted to go beyond that.  A
simple method for interpreting the response is to use regular expression
matching to extract the desired information.  One would then typically
want to convert that text into some more appropriate value (e.g. a
double) in the driver.
A more powerful approach would be to actually provide an HTML or XML
parser allowing access to the response via SAX or a DOM.  I'm not sure
how this would work for devices that return invalid HTML or XML
responses.  I would bet that many devices do not actually respond with
valid HTML or XML.
Lewis
---------------------------------------------------------- Pete R. Jemian, Ph.D.<[email protected]> Beam line Controls and Data Acquisition, Group Leader Advanced Photon Source, Argonne National Laboratory Argonne, IL 60439 630 - 252 - 3189 ----------------------------------------------------------- Education is the one thing for which people are willing to pay yet not receive. -----------------------------------------------------------
HTML Device Driver David Dudley
Re: HTML Device Driver J. Lewis Muir
Prev: Re: HTML Device Driver J. Lewis Muir
Next: RE: Analog output device support design Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Re: HTML Device Driver Rod Nussbaumer
