David Dudley wrote:
Here’s a new one for you (Got Ralph and Michael going about how to do
it, anyway ;-)
Almost all of the PLC equipment we’re going to be using on NSLS/2 is
connected on Ethernet.
It is common practice in the communications modules now, to integrate an
embedded WEB server into the device. Both the Siemens and Rockwell
hardware we’re going to use have that capability, as well as most of the
new generation of instrumentation.
Does anyone have knowledge of an EPICS device driver that is capable of
reading and interpreting a WEB page or XML page? Seems that this would
be the most universal way to read data from all this differing
equipment, if such a driver was available.
David Dudley
I used StreamDevice + Asyn to acquire data from an ethernet attached
instrument containing a built-in web server. It required a minor bit of
reverse engineering the HTML code, which was quite simple, and took just
a little bit of tutoring from Dirk to get things right. Although the
server was not intended for this purpose, the scheme worked well enough.
In the second design iteration of the instrument, they changed the web
interface to make it more user friendly. It now uses a Java applet which
downloads to the browser, and the applet communicates with the server,
or some such stuff that is indecipherable from the standpoint of EPICS
support. Given a second lifetime, I might get around to creating EPICS
support capable of dealing with that problem. Is an evolving standard
like HTML a good thing to rely on for a control system?
Rod Nussbaumer
ISAC Controls, TRIUMF
Vancouver, Canada
- HTML Device Driver David Dudley
RE: Developing of record / driver / device support? Asyn? Mark Rivers
Re: Tech-talk archives excluded from indexing? Andrew Johnson
<2010>
2025
2026
Re: HTML Device Driver Pete Jemian
Re: HTML Device Driver emmanuel_mayssat
<2010>
2025
2026
ANJ, 02 Sep 2010 |
Home
News
About
Talk
Base
Modules
Extensions
Distributions
Download
Documents
Links
Licensing
