1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: edm meter
To: "'Andrew Johnson'" <[email protected]>, <[email protected]>
Date: Mon, 23 Aug 2010 14:38:25 -0600
Sorry didn’t read entire thread.
Ø  In R3.14.11 we added a new CA subscription event type called DBE_PROPERTY
The correct approach from my perspective, but possibly this will prove to be a bit too general
of an event category as this feature starts to be extensively used.
Jeff
______________________________________________________
Jeffrey O. Hill           Email
[email protected]
LANL MS H820              Voice        505 665 1831
Los Alamos NM 87545 USA   FAX          505 665 5107
Message content: TSPA
From: [email protected] [mailto:[email protected]] On Behalf Of Andrew Johnson
Sent: Monday, August 23, 2010 12:02 PM
To: [email protected]
Subject: Re: edm meter
On Monday 23 August 2010 12:20:37 Till Straumann wrote:
> IIRC there are some widgets that use or could use information
> which is available via DBR_GR_xxx CA transfers but which
> do not properly track changes of the data attributes (such as units or
> limits).
> It looks like these attributes are only fetched when a connection is
> created and then cached by EDM.
The problem with trying to update those attributes with a monitor is that the IOC never posts an event when the attribute value changes (changing HOPR or LOPR as Wes is looking for doesn't mean that VAL changed or the record was processed, so a regular monitor subscription doesn't do what he wants). The EDM client code *could* explicitly monitor the HOPR and LOPR fields itself, but that would be embedding record-specific knowledge into a CA client which then wouldn't work properly with a non-IOC CA server.
In R3.14.11 we added a new CA subscription event type called DBE_PROPERTY (the others are DBE_ALARM, DBE_VALUE and DBE_ARCHIVE) which the IOC will eventually post whenever an attribute value changes. A CA client can therefore subscribe for DBE_PROPERTY events from a channel using one of the DBR_GR_xxx types to get informed of these kinds of changes.
However currently DBE_PROPERTY events only get generated when the menu strings of a mbbi or mbbo record are changed; no other record types post DBE_PROPERTY events, and it's not a trivial matter to add them. We will need to extend the DBD file format and probably modify the record interface to do this properly.
The point of adding DBE_PROPERTY events now was to allow CA client programs to be modified to make use of this, i.e. replace the ca_get_callback() of the DBR_GR_xxx data that they currently do at connection time with a CA monitor of that same DBR_GR_xxx type for DBE_PROPERTY updates. They will get one update whenever the channel (re)connects to current IOCs, and in the future hopefully they'll get sent more updates once we've added the necessary functionality to the IOC database code.
- Andrew
The best FOSS code is written to be read by other humans -- Harald Welte
Re: edm meter Andrew Johnson
edm meter Wesley Moore
Re: edm meter Till Straumann
Prev: RE: edm meter Jeff Hill
Next: Re: edm meter Andrew Johnson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
