1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Firewall (iptables) issues?
To: Till Straumann <[email protected]>
Cc: [email protected]
Date: Fri, 5 Nov 2010 15:55:24 -0700
Right.
How about adding 'Additionally' at the beginning of the second paragraph?
On Nov 5, 2010, at 3:24 PM, Till Straumann wrote:
> IMO it would be prudent to recommend that a machine hosting soft-iocs
> should also open incoming traffic on the repeater port since it is
> possible that soft-iocs contain CA links and therefore are clients, too.
> (And the network administrator normally doesn't know about the IOC
> internals.)
> -- T.
> On 11/05/2010 03:31 PM, Eric Norum wrote:
>> Thanks to input from Jeff Hill, Ralph Lange, and Andrew Johnson I think that the following is an accurate description of the firewall settings needed to support channel access.
>> If you want channel access clients on a machine to be able to see beacons and replies to broadcast PV search requests you need to permit inbound UDP packets with source port EPICS_CA_SERVER_PORT (default is 5064) or destination port EPICS_CA_REPEATER_PORT (default is 5065).  On systems using iptables this can be accomplished by rules like
>> 	-A INPUT -s 192.168.0.0/22 -p udp --sport 5064 -j ACCEPT
>> 	-A INPUT -s 192.168.0.0/22 -p udp --dport 5065 -j ACCEPT
>> If you want channel access servers (e.g. "soft IOCs") on a machine to be able to see clients you need to permit inbound TCP or UDP packets with source port EPICS_CA_SERVER_PORT (default is 5064).  On systems using iptables this can be accomplished by rules like
>> 	-A INPUT -s 192.168.0.0/22 -p udp --dport 5064 -j ACCEPT
>> 	-A INPUT -s 192.168.0.0/22 -p tcp --dport 5064 -j ACCEPT
>> The above sets of rules are complete assuming that there's no blocking of outbound traffic.
>> In all cases the "-s 192.168.0.0/22" specifies the range of addresses from which you wish to accept packets.
Eric Norum
[email protected]
Firewall (iptables) issues? Eric Norum
Re: Firewall (iptables) issues? Ralph Lange
Re: Firewall (iptables) issues? Eric Norum
Re: Firewall (iptables) issues? Till Straumann
Prev: Re: Firewall (iptables) issues? Eric Norum
Next: Re: Options for reviving old Allen Bradley PLC implementations jun-ichi.odagiri
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Firewall (iptables) issues? Till Straumann
Next: iOS EPICS Channel Access Pelaia II, Tom
ANJ, 06 Nov 2010 · Home · News · About · Talk · Base · Modules · Extensions ·
