1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: [SOLVED] RE: subrecord INPx
To: Hinko Kocevar <[email protected]>, EPICS Tech Talk <[email protected]>
Date: Wed, 24 Nov 2010 11:11:47 -0800
Hi Hinko,
You found the bug in the subRecord that is documented (with a patch) in the 3.14.10 known problems:
http://epics.aps.anl.gov/epics/base/R3-14/10-docs/KnownProblems.html
It's a good idea to check the known bugs and apply the patches before building!  You might want to check the 3.14.11 known bugs now.
Stephanie
> -----Original Message-----
> From: [email protected] [mailto:[email protected]] On Behalf Of
> Hinko Kocevar
> Sent: Wednesday, November 24, 2010 11:02 AM
> To: Hinko Kocevar; Eric Norum; EPICS Tech Talk
> Subject: [SOLVED] RE: subrecord INPx
> Hi all,
> I've tried with base 3.14.11 and it worked:
> ## Start any sequence programs
> #seq sncExample, "user=hinkoHost"
> epics> precord->a 1.000000
> precord->b 123.000000
> precord->a 2.000000
> precord->a 3.000000
> precord->a 4.000000
> I guess it is my time to move on with the EPICS base release ;).
> Thank you all!
> Best regards,
> Hinko
> From: [email protected] on behalf of Hinko Kocevar
> Sent: Wed 11/24/2010 7:44 PM
> To: Eric Norum; EPICS Tech Talk
> Subject: RE: subrecord INPx
> Hi Eric,
> On 11/24/10 19:16, Eric Norum wrote:
> > Are you sure that your EPICS base and test application are built properly?
> I did a make clean in base and removed my install folder. Remade the base
> and used makeBaseApp.pl to recreate the example IOC - result is the same!?
> > When I run this I see:
> > precord->a 2.000000
> > precord->a 3.000000
> > precord->a 4.000000
> > Looks right to me.
> To me too.
> I'm glad that code works.. I'll go and re-get the base sources from the web
> and give it another stab :S
> Thank you!
> Best regards,
> Hinko
> On Nov 24, 2010, at 6:49 AM, Hinko Kocevar wrote:
> > Hi,
> > I'm poking around the example IOC I've created with:
> > $ makeBaseApp.pl -t example app1
> > $ makeBaseApp.pl -i -t example app1
> > Example runs fine and records are behaving as expected, but..
> > I tried to experiment with subRecord, but the mySubProcess routine does not seem to get values
> on INPx fields if they are not constants. I've added following line to get INPA value inside the C
> function:
> > static long mySubProcess(subRecord *precord)
> >    if (mySubDebug)
> >        printf("Record %s called mySubProcess(%p)\n",
> >               precord->name, (void*) precord);
> >    printf("precord->a %lf\n", precord->a);
> >    printf("precord->b %lf\n", precord->b);
> >    return 0;
> > Example:
> > record(sub,"$(user):subExample")
> >    field(INAM,"mySubInit")
> >    field(SNAM,"mySubProcess")
> >    field(INPA, "$(user):subInc")
> >    field(INPB, "123")
> > record(calc, "$(user):subInc") {
> >  field(SCAN, "1 second")
> >  field(VAL, "0")
> >  field(CALC, "(A+1)")
> >  field(INPA, "$(user):subInc.VAL NPP")
> > Output from IOC:
> > Record hinkoHost:subcall called mySubProcess(0x9205998)
> > precord->a 0.000000
> > precord->a 0.000000
> > precord->a 0.000000
> > At the same time, if I monitor the $(user):subInc:
> > camonitor hinkoHost:subInc
> > hinkoHost:subInc               2010-11-24 15:45:57.346136 14
> > hinkoHost:subInc               2010-11-24 15:45:58.346438 15
> > hinkoHost:subInc               2010-11-24 15:45:59.346628 16
> > What am I missing?
> > Best regards,
> > Hinko
> > Hinko Kocevar
> > Technical support software engineer
> > Instrumentation Technologies d.d.
> > Velika pot 22, SI-5250 Solkan - Slovenia
> > T:+386 5 3352600, F:+386 5 3352601
> > mailto: [email protected]
> > http://www.i-tech.si - When your users demand stability
> > The information transmitted is intended solely for the addressee and may
> > contain confidential and/or privileged information. Any review, retention,
> > disclosure or other use by persons other than the intended recipient is
> > prohibited. If you received this in error, please notify the sender and
> > delete all copies.
> Eric Norum
> [email protected]
RE: [SOLVED] RE: subrecord INPx Hinko Kocevar
Re: subrecord INPx Eric Norum
Prev: [SOLVED] RE: subrecord INPx Hinko Kocevar
Next: RE: [SOLVED] RE: subrecord INPx Hinko Kocevar
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
ANJ, 24 Nov 2010 · Home · News · About · Talk · Base · Modules · Extensions ·
