1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: rtems-4.10 tftp support
To: Daron Chabot <[email protected]>
Date: Thu, 9 Dec 2010 09:20:58 -0800
--- /usr/local/epics/R3.14.12/base/src/RTEMS/base/rtems_init.c 2010-11-24 12:54:36.000000000 -0800
+++ rtems_init.c 2010-12-09 09:18:34.270548000 -0800
@@ -209,7 +209,15 @@
 #ifdef OMIT_NFS_SUPPORT
     printf ("***** Initializing TFTP *****\n");
+#if __RTEMS_MAJOR__>4 || (__RTEMS_MAJOR__==4 && __RTEMS_MINOR__>9) || (__RTEMS_MAJOR__==4 && __RTEMS_MINOR__==9 && __RTEMS_REVISION__==99)
+    mount_and_make_target_path(NULL,
+                               "/TFTP",
+                               RTEMS_FILESYSTEM_TYPE_TFTPFS,
+                               RTEMS_FILESYSTEM_READ_WRITE,
+                               NULL);
+#else
     rtems_bsdnet_initialize_tftp_filesystem ();
+#endif
     if (!hasLocalFilesystem) {
         char *path;
         int pathsize = 200;
On Dec 9, 2010, at 9:06 AM, Daron Chabot wrote:
Hi Jim,
Have a look at tftpTest/init.c from the RTEMS network-demos (cvs HEAD):
cvs -d :pserver:[email protected]:/usr1/CVS co network-demos
It looks like the new initialization steps are:
        rtems_bsdnet_initialize_network ();
                NULL,
                "/TFTP",
                NULL
Patches to Base welcome :-)
-- dc
On Thu, Dec 9, 2010 at 11:26 AM, Jim Chen <[email protected]> wrote:
Eric,
It seems like that rtems-4.10 has changed some function prototypes in
tftpDriver.c code such as rtems_bsdnet_initialize_tftp_filesystem (doesn't
exist anymore) which fails the build of EPICS3.14.11/12 that doesn't use NFS
(with OMIT_NFS_SUPPORT defined). Is there a particular reason for this and
how can I get around with this please?
Best regards,
Jim
Hytec Electronics Ltd.
Tel: +44 (0) 118 975 7770
Fax: +44 (0) 118 975 7566
Web: www.hytec-electronics.co.uk
Incorporated in England No 1246940
VAT NO GB 285 2479 27
Eric Norum
[email protected]
RE: rtems-4.10 tftp support Jim Chen
Re: rtems-4.10 tftp support Daron Chabot
Asyn VXI-11 Driver and VXI-11 Locking William Lu
Re: Asyn VXI-11 Driver and VXI-11 Locking Eric Norum
Re: Asyn VXI-11 Driver and VXI-11 Locking William Lu
Prev: Re: rtems-4.10 tftp support Daron Chabot
Next: RE: rtems-4.10 tftp support Jim Chen
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
ANJ, 09 Dec 2010 · Home · News · About · Talk · Base · Modules · Extensions ·
