1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: large arrays native element count wrong with Channel Access inEPICS 3.14.12
To: "'Michael Abbott'" <[email protected]>, "'Mark Rivers'" <[email protected]>
Cc: [email protected]
Date: Thu, 13 Jan 2011 10:30:07 -0700
Not a problem, I think that I did also review the changes, but it's not
always possible (efficient) to detect issues when staring at the code for a
limited length of time.
Hopefully soon we can better automate client / server test permutations so
that the regression tests provide better coverage.
Jeff
______________________________________________________
Jeffrey O. Hill           Email        [email protected]
LANL MS H820              Voice        505 665 1831
Los Alamos NM 87545 USA   FAX          505 665 5107
Message content: TSPA
With sufficient thrust, pigs fly just fine. However, this is
not necessarily a good idea. It is hard to be sure where they
are going to land, and it could be dangerous sitting under them
as they fly overhead. -- RFC 1925
> -----Original Message-----
> From: Michael Abbott [mailto:[email protected]]
> Sent: Thursday, January 13, 2011 9:52 AM
> To: Mark Rivers
> Cc: Jeff Hill; [email protected]
> inEPICS 3.14.12
> That appears to be my fault, I'm very sorry about that.  Bug 701673 is a
> revert of this commit:
> http://bazaar.launchpad.net/~michael-abbott/epics-base/dynamic-
> array/revision/12076
> Unfortunately I'm rusty enough that I can't see the error right now, and
> I'm tied up away from the office for a few days now.  Thanks very much
> for
> finding and fixing this.
> I don't remember at all why that commit was created in the first place,
> as
> it seems rather pointless really.
> I guess this shows the hazards of working on a code base very part time
> On Wed, 12 Jan 2011, Mark Rivers wrote:
> > Hi Jeff,
> > Thanks for the quick response.  I installed the patch and it fixes the
> problem.
> > Mark
> > From: [email protected] on behalf of Jeff Hill
> > Sent: Wed 1/12/2011 5:21 PM
> > To: [email protected]
> > I committed a fix to the R3.14 branch. An overzealous optimization was
> > installed. See bug 701673 at launchpad for the details.
> > https://bugs.launchpad.net/epics-base/+bug/701673
> > Jeff
> > > From: Jeff Hill [mailto:[email protected]]
> > > Sent: Wednesday, January 12, 2011 9:27 AM
> > > To: '[email protected]'
> > > Subject: RE: Problem using large arrays with Channel Access in EPICS
> > > 3.14.12
> > > Yes, there were two new features merged into CA for the R3.14.12
> patch
> > > release. I will have a look.
> > > PS: IMHO, we can consider that risk is reduced if only patches are
> merged
> > > into patch releases. Perhaps new features are best placed in point
> > > releases.
> > > Jeff
> > > > From: [email protected] [mailto:tech-talk-
> > > > [email protected]] On Behalf Of Andrew Johnson
> > > > Sent: Tuesday, January 11, 2011 2:43 PM
> > > > Subject: Re: Problem using large arrays with Channel Access in
> EPICS
> > > > 3.14.12
> > > > On Tuesday 11 January 2011 15:21:32 Till Straumann wrote:
> > > > > Could be a limitation of the CA protocol
> > > > No, this is as a result of changes in src/rsrv between 3.14.11 and
> > > > 3.14.12
> > > > because large arrays work fine in 3.14.11.
> > > > We introduced two major new features in the latest release, CA over
> TCP
> > > > and
> > > > dynamic array sizing, and one of them (most probably the latter)
> has
> > > > broken
> > > > the correct reporting of the element count.  The CA protocol solved
> the
> > > > problem of only a having a 16 bit m_count field a long time ago,
> but it
> > > > looks
> > > > like that hack^H^H^H^Hsolution didn't get propagated into the
> latest
> > > > code.
> > > > - Andrew
> > > > If a man is offered a fact which goes against his instincts, he
> will
> > > > scrutinize it closely, and unless the evidence is overwhelming, he
> will
> > > > refuse to believe it.  If, on the other hand, he is offered
> something
> > > > which affords a reason for acting in accordance to his instincts,
> he
> > > > will accept it even on the slightest evidence.  -- Bertrand Russell
Problem using large arrays with Channel Access in EPICS 3.14.12 Mark Rivers
Re: Problem using large arrays with Channel Access in EPICS 3.14.12 Till Straumann
Re: Problem using large arrays with Channel Access in EPICS 3.14.12 Andrew Johnson
RE: large arrays native element count wrong with Channel Access in EPICS 3.14.12 Jeff Hill
RE: large arrays native element count wrong with Channel Access inEPICS 3.14.12 Mark Rivers
RE: large arrays native element count wrong with Channel Access inEPICS 3.14.12 Michael Abbott
Prev: Access to records from subroutines during iocInit Rod Nussbaumer
Next: RE: MOXA terminal server Xu, Huijuan
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: large arrays native element count wrong with Channel Access inEPICS 3.14.12 Michael Abbott
Next: Re: large arrays native element count wrong with Channel Access in EPICS 3.14.12 Ernest L. Williams Jr.
