I'm not sure what you mean by "never set puser to anything else other than
zero."?
> On Friday 28 January 2011 11:56:37 [email protected] wrote:
>> So:
>> void cleanup(chid ChanID) {
>> void* pUserPrivate;
>> pUserPrivate = ca_puser(ChanID);
>> free(pUserPrivate);
>> ca_clear_channel(ChanID);
> Looks reasonable, assuming you used the {m|c|re}alloc() routine to get the
> pointer in the first place and you never set puser to anything else other
> than
> zero.
> BTW on Windows you have to call free() from the same DLL as the *alloc()
> call.
> - Andrew
> If a man is offered a fact which goes against his instincts, he will
> scrutinize it closely, and unless the evidence is overwhelming, he will
> refuse to believe it. If, on the other hand, he is offered something
> which affords a reason for acting in accordance to his instincts, he
> will accept it even on the slightest evidence. -- Bertrand Russell
- Re: ca_create_channel memory management Andrew Johnson
- ca_create_channel memory management pthomas
- Re: ca_create_channel memory management pthomas
Re: epicsMessageQueue Linux PREEMPT_RT Till Straumann
<2011>
2025
2026
<2011>
2025
2026
