1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: Asyn record DBD
To: "Rod Nussbaumer" <[email protected]>, <[email protected]>
Date: Wed, 23 Feb 2011 13:48:21 -0600
Hi Rod,
The IFACE field of the asyn record controls which asyn interface the
asyn record tries to use when it does actual I/O.  Most frequently the
asyn record is used with the asynOctet interface, but it can also be
used with asynInt32, asynFloat64, etc.
Are you talking about GUI tools like medm?  If so, they definitely don't
require the promptgroup(GUI_DISPLAY) for the IFACE field in the DBD
file.  You can see that from the documentation for the asynRecord:
http://www.aps.anl.gov/epics/modules/soft/asyn/R4-16/asynRecord.html
It contains medm screen shots that include the IFACE menu, which works
fine.
I don't know what the meaning of promptgroup(GUI_DISPLAY) is.  Is it
documented anywhere?  Does capfast use that to know that it should
display it as a menu or something?
It is certainly not needed in the record definition in the IOC.  The
only thing the IOC needs to know is that the field is of type DBF_MENU.
-----Original Message-----
[mailto:[email protected]] On Behalf Of Rod Nussbaumer
Sent: Wednesday, February 23, 2011 12:28 PM
To: [email protected]
Subject: Asyn record DBD
Hi all.
I response to the recent discussion of the asyn record for invoking IOC
shell commands, I have tried to set up a Capfast configuration for the
asyn record. To do this, I have inspected the asyn record DBD file, and
am extracting the crucial bits to a Capfast symbol file and to the
edb.def file used in the Capfast -> EPICS .db file conversion. In the
DBD file, I see the following snippet:
     field(IFACE,DBF_MENU) {
         prompt("Interface")
         menu(asynINTERFACE)
         special(SPC_MOD)
Since I haven't yet come to a good understanding of the behavior of the
asyn record, I cannot say for sure, but it seems to me that the record's
interface method is a vital configuration issue, and that GUI tools can
only use the IFACE field's configuration if there is also the
element added to the DBD file for the IFACE field description.
Is this correct, or do I simply not understand the record and/or the
meaning of the DBD file elements?
Rod Nussbaumer
ISAC Controls, TRIUMF
Vancouver, Canada.
Asyn record DBD Rod Nussbaumer
Prev: RE: epics on FreeBSD: broadcast problem Jeff Hill
Next: Re: Asyn record DBD Andrew Johnson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Asyn record DBD Rod Nussbaumer
