1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Asyn record DBD
To: [email protected]
Date: Wed, 23 Feb 2011 10:27:58 -0800
Hi all.
I response to the recent discussion of the asyn record for invoking IOC shell commands, I have tried to set up a Capfast configuration for the asyn record. To do this, I have inspected the asyn record DBD file, and am extracting the crucial bits to a Capfast symbol file and to the edb.def file used in the Capfast -> EPICS .db file conversion. In the DBD file, I see the following snippet:
    field(IFACE,DBF_MENU) {
        prompt("Interface")
        menu(asynINTERFACE)
        special(SPC_MOD)
Since I haven't yet come to a good understanding of the behavior of the asyn record, I cannot say for sure, but it seems to me that the record's interface method is a vital configuration issue, and that GUI tools can only use the IFACE field's configuration if there is also the
	        promptgroup(GUI_DISPLAY)
element added to the DBD file for the IFACE field description.
Is this correct, or do I simply not understand the record and/or the meaning of the DBD file elements?
Rod Nussbaumer
ISAC Controls, TRIUMF
Vancouver, Canada.
RE: Asyn record DBD Mark Rivers
Re: Asyn record DBD Andrew Johnson
Prev: Re: epics on FreeBSD: broadcast problem emmanuel_mayssat
Next: RE: epics on FreeBSD: broadcast problem Jeff Hill
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: epics on FreeBSD: broadcast problem Gerrit Kühn
Next: RE: Asyn record DBD Mark Rivers
