1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: epics on FreeBSD: broadcast problem
Cc: [email protected]
Date: Thu, 24 Mar 2011 15:52:24 +0100
On Tue, 15 Mar 2011 08:57:24 -0600 Andrew Johnson <[email protected]> wrote
about Re: epics on FreeBSD: broadcast problem:
Hi Andrew,
AJ> I certainly want to fold back any necessary changes into Base, and I
AJ> can forward any other substantive changes to Janet who manages
AJ> extensions and MEDM.  We don't currently have an active maintainer for
AJ> FreeBSD which is why the code that we do have for it didn't work
AJ> properly for you.  Please send me a patch file and I'll take a look.
Ok, I have repeated everything with a clean system now to find out what is
actually needed and working. For the epics base I have just the change
Jeff recommended to get the broadcast working:
diff --git a/src/libCom/osi/os/freebsd/osdSock.h b/src/libCom/osi/os/freebsd/osdSock.h
index 0b9e515..8c270b7 100644
--- a/src/libCom/osi/os/freebsd/osdSock.h
+++ b/src/libCom/osi/os/freebsd/osdSock.h
@@ -77,7 +77,11 @@ typedef socklen_t osiSocklen_t;
 #   define SHUT_RDWR 2
 #endif
-#define ifreq_size(pifreq) (sizeof(pifreq->ifr_name))
+#if BSD4_4
+#   define ifreq_size(pifreq) (pifreq->ifr_addr.sa_len + sizeof(pifreq->ifr_name))
+#else
+#   define ifreq_size(pifreq) sizeof(*pifreq)
+#endif
 #endif /*osdSockH*/
For the extensions I had to add the following directories in configure/os/CONFIG_SITE.freebsd-x86_64.freebsd-x86_64 to get medm compiled (X11 and MOTIF paths):
ahvbuildbox-fbsd64# cat CONFIG_SITE.freebsd-x86_64.freebsd-x86_64
# CONFIG_SITE.freebsd-x86_64.freebsd-x86_64,v 1.1 2006/12/04 22:28:29 jba Exp
# Site Specific Configuration Information
# Only the local epics system manager should modify this file
# Where to find utilities/libraries
#       If you do not have a certain product,
#       leave the line empty.
X11_LIB = /usr/local/lib
X11_INC = /usr/local/include
MOTIF_INC = $(X11_INC)
MOTIF_LIB = $(X11_LIB)
For x86 platform (32bit), the file was missing completely, so I created it:
ahvbuildbox-fbsd32# cat CONFIG_SITE.freebsd-x86.freebsd-x86
# CONFIG_SITE.freebsd-x86.freebsd-x86
For both files, I chose the default directories that you get by installing Xorg and OpenMotif via FreeBSD's port collection (which should be the standard case).
Finally, for the gateway extension I noticed that it was compiling fine on the 64bit target, but gave me errors when compiling on 32bit. These errors were caused by wrong type casting in gateResources.cc:
/usr/bin/g++ -c  -D_POSIX_THREADS           -D_X86_  -DUNIX  -D_BSD_SOURCE -Dfreebsd  -D_REENTRANT   -O3   -Wall     -DSTAT_PVS -DRATE_STATS -DCONTROL_PVS -DCAS_DIAGNOSTICS -DHANDLE_EXCEPTIONS -DUSE_DENYFROM       -MMD -I. -I../O.Common -I. -I.. -I/opt/epics/epics/include/os/freebsd -I/opt/epics/epics/include -I/opt/epics/epics/include/os/freebsd -I/opt/epics/epics/include         -I/opt/epics/epics/src/cas/generic   ../gateResources.cc
../gateResources.cc: In function 'char* timeStamp()':
../gateResources.cc:58: error: invalid conversion from 'long int*' to 'time_t*'
../gateResources.cc:58: error:   initializing argument 1 of 'time_t time(time_t*)'
../gateResources.cc:59: error: invalid conversion from 'long int*' to 'const time_t*'
../gateResources.cc:59: error:   initializing argument 1 of 'tm* localtime(const time_t*)'
gmake[1]: *** [gateResources.o] Error 1
gmake[1]: Leaving directory `/root/epics/extensions/src/gateway2_0_4_0/O.freebsd-x86'
gmake: *** [install.freebsd-x86] Error 2
I fixed this by replacing "long" type with "time_t". This way it compiled for me without errors on 32bit and 64bit, but I don't know if this is the proper fix for all platforms:
diff --git a/src/gateway2_0_4_0/gateResources.cc b/src/gateway2_0_4_0/gateResources.cc
index 5e74cdd..2fa2f21 100644
--- a/src/gateway2_0_4_0/gateResources.cc
+++ b/src/gateway2_0_4_0/gateResources.cc
@@ -51,13 +51,13 @@ gateResources* global_resources;
 // should copy it to a safe place e.g. strcpy(savetime,timestamp());
 char *timeStamp(void)
-       static char timeStampStr[16];
-       long now;
+       static char timeStampStr[20];
+       time_t now;
        struct tm *tblock;
        time(&now);
        tblock=localtime(&now);
-       strftime(timeStampStr,20,"%b %d %H:%M:%S",tblock);
+       strftime(timeStampStr,sizeof(timeStampStr),"%b %d %H:%M:%S",tblock);
        return timeStampStr;
cu
  Gerrit
epics on FreeBSD: broadcast problem Gerrit Kühn
Re: epics on FreeBSD: broadcast problem Gerrit Kühn
Prev: New "model 3" motor driver for Parker ACR controllers Mark Rivers
Next: PyEpics 3.1.0 Matt Newville
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: epics on FreeBSD: broadcast problem Andrew Johnson
Next: Asyn record DBD Rod Nussbaumer
