1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: epics on FreeBSD: broadcast problem
To: "Jeff Hill" <[email protected]>
Cc: [email protected]
Date: Tue, 15 Mar 2011 11:44:03 +0100
On Fri, 25 Feb 2011 11:46:12 -0700 "Jeff Hill" <[email protected]> wrote
about RE: epics on FreeBSD: broadcast problem:
Hi Jeff,
JH> These headers are intended to be private to the internal
JH> implementation of the portable server, but the gateway has become
JH> dependent on them. Copying them to the install location is probably
JH> the best workaround at the moment.
I wanted to let you know that the gateway is running fine here on my
test machine for more than a week now after the changes you recommended.
Thank you for your support!
To get things working, I had to change/add some configuration stuff that is
probably generic for running epics on FreeBSD. I'll have to compile a
short list of these things and will probably create FreeBSD ports for my
machines here installing at least epics, extensions, medm. Would it be
worth trying to get FreeBSD folks to offer some "official" port
(<http://www.freebsd.org/ports/index.html>), or could some of these things
be integrated into a later epics distribution?
cu
  Gerrit
Re: epics on FreeBSD: broadcast problem Andrew Johnson
epics on FreeBSD: broadcast problem Gerrit Kühn
Re: epics on FreeBSD: broadcast problem Gerrit Kühn
Prev: Message logging survey Hall, Robert D.
Next: Re: epics on FreeBSD: broadcast problem Andrew Johnson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: epics on FreeBSD: broadcast problem Jeff Hill
