1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: epics on FreeBSD: broadcast problem
To: [email protected], [email protected]
Date: Tue, 15 Mar 2011 08:57:24 -0600
Hi Gerrit,
On Tuesday 15 March 2011 05:44:03 Gerrit Kühn wrote:
> To get things working, I had to change/add some configuration stuff that is
> probably generic for running epics on FreeBSD. I'll have to compile a
> short list of these things and will probably create FreeBSD ports for my
> machines here installing at least epics, extensions, medm. Would it be
> worth trying to get FreeBSD folks to offer some "official" port
> (<http://www.freebsd.org/ports/index.html>), or could some of these things
> be integrated into a later epics distribution?
I certainly want to fold back any necessary changes into Base, and I can
forward any other substantive changes to Janet who manages extensions and
MEDM.  We don't currently have an active maintainer for FreeBSD which is why
the code that we do have for it didn't work properly for you.  Please send me
a patch file and I'll take a look.
- Andrew
An error is only a mistake if you don't learn from it.
When you learn something from it, it becomes a lesson.
epics on FreeBSD: broadcast problem Gerrit Kühn
Re: epics on FreeBSD: broadcast problem Gerrit Kühn
Prev: Re: epics on FreeBSD: broadcast problem Gerrit Kühn
Next: 'Feature' of subArray record graham.cox
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Re: epics on FreeBSD: broadcast problem Gerrit Kühn
