Title: RE: Problem with Motor Record on RTEMS on MVME5500
Hi Kate,
Thank you very much for that! That did the trick.
Jim Eastman
-----Original Message-----
Sent: Tue 01-Mar-11 08:54
To: Jim Eastman
Cc: EPICS Tech Talk
Subject: Re: Problem with Motor Record on RTEMS on MVME5500
Jim Eastman wrote:
> Hi all,
> So continuing to learn my way through all of this, I'm encountering a
> problem with using the motor record to control a MAXv. The basic
> setup: an MVME5500 running RTEMS 4.10 (with the bspExt code for the
> mvme5500), and I've tried both 3.14.11 and 3.14.12 versions of EPICS
> using version 6-5-2 of the motor record. Building and deploying the
> NoAsyn example app.
> Here is my startup output:
> Welcome to rtems-4.10.0(PowerPC/Generic (classic FPU)/mvme5500) on
> MVME5500-0163
> Now BSP_mem_size = 0x1FE00000
> Marvell GT64260B (Discovery I) hostbridge detected at bus0 slot0
> BSP unlisted vendor, Bus0 Slot10 DeviceID 0x263388
> TUNDRA PCI-VME bridge detected at bus1 slot0
> Marvell GT64260B (Discovery I) hostbridge detected at bus8 slot0
> BSP unlisted vendor, Bus8 Slot10 DeviceID 0x10088086
> Universe II PCI-VME bridge detected at 0x82000000, IRQ 12
> Universe Master Ports:
> Port VME-Addr Size PCI-Adrs Mode:
> 0: 0x20000000 0x0E000000 0x90000000 A32, D64 [MBLT], Dat, Sup
> 1: 0x00000000 0x00FF0000 0x9F000000 A24, D64 [MBLT], Dat, Sup
> 2: 0x00000000 0x00010000 0x9FFF0000 A16, D64, Dat, Sup
> Universe Slave Ports:
> 0: 0x90000000 0x1FE00000 0x00000000 A32, Pgm, Dat, Sup, Usr, PWEN,
> PREN
> Overriding main IRQ line PCI info with 76
> Registering /dev/console as minor 0 (==/dev/ttyS0)
> ***** Initializing network *****
> Startup.
> Attaching MVME5500 1GHz NIC1
> RTEMS-mvme5500 BSP Copyright (c) 2004,2005,2008, Brookhaven National
> Lab., Shuchen Kate Feng
> ***** Initializing NFS *****
> Mount 10.40.30.108:/tftpboot/epics on /epics
> RTEMS-RPCIOD $Release$, Till Straumann, Stanford/SLAC/SSRL 2002, See
> LICENSE file for licensing info.
> RTEMS-NFS $Release$, Till Straumann, Stanford/SLAC/SSRL 2002, See
> ***** Starting EPICS application *****
> #Startup script for loading and configuring an OMS MAXv controller.
> < /epics/mvme5500/envPaths
> epicsEnvSet("ARCH","RTEMS-mvme5500")
> epicsEnvSet("IOC","iocNoAsyn")
> dbLoadDatabase("/epics/mvme5500/dbd/motorRecord.dbd")
> dbLoadDatabase("/epics/mvme5500/dbd/devOms.dbd")
> dbLoadDatabase("/epics/mvme5500/dbd/NoAsyn.dbd")
> NoAsyn_registerRecordDeviceDriver(pdbbase)
> dbLoadTemplate("/epics/mvme5500/motor.substitutions")
> MAXvSetup(1, 16, 0xF000, 190, 5, 10)
> MAXvConfig(0, "AX LL PSO; AY LL PSO; AZ LL PSO; AT LL PSO; AU LH PSO;
> AV LH PSO; AR LH PSO; AS LH PSO;")
> iocInit
> Starting iocInit
> ## EPICS R3.14.12 $Date: Wed 2010-11-24 14:50:38 -0600$
> ## EPICS Base built Feb 25 2011
> libbspExt - Warning: it seems that MCP support is not available on
> your CPU
> or not implemented by your board. Address probing
> must
> be performed in polling mode with interrupts
> disabled
> Warning: bspExtMemProbe kills real-time performance.
> Your BSP does or can not use MCP exceptions - we
> must probe with INTERRUPTS DISABLED !!!
> use only during driver initialization
> clear the 'bspExtVerbosity' variable to silence this warning
> Illegal field value PV: IOC:m1 motor_init_record_com(): card does not
> exist!
The jumper on the board is manufactured set to be "user mode". One
needs to set it
to a "Supervisory mode" to get it working. Hope this helps. I would
have to find the
user's manual to find out which jumper it is.
Cheers,
Kate
> Illegal field value PV: IOC:m2 motor_init_record_com(): card does not
> exist!
> Illegal field value PV: IOC:m3 motor_init_record_com(): card does not
> exist!
> Illegal field value PV: IOC:m4 motor_init_record_com(): card does not
> exist!
> Illegal field value PV: IOC:m5 motor_init_record_com(): card does not
> exist!
> Illegal field value PV: IOC:m6 motor_init_record_com(): card does not
> exist!
> Illegal field value PV: IOC:m7 motor_init_record_com(): card does not
> exist!
> Illegal field value PV: IOC:m8 motor_init_record_com(): card does not
> exist!
> iocRun: All initialization complete
> Here's what my motor.substitutions file looks like:
> file "/epics/mvme5500/db/basic_motor.db"
> pattern
> {P, N, M, DTYP, C, S, DESC,
> EGU, DIR, VELO, VBAS, ACCL, BDST, BVEL, BACC, MRES,
> PREC, DHLM, DLLM, INIT, PREM, POST}
> {IOC:, 1, "m$(N)", "OMS MAXv", 0, 0, "motor axis $(N)",
> degrees, Pos, 1, .1, .2, 0, 1, .2, 0.01,
> 5, 100, -100, "AN LL", "AF", "AN"}
> {IOC:, 2, "m$(N)", "OMS MAXv", 0, 1, "motor axis $(N)",
> {IOC:, 3, "m$(N)", "OMS MAXv", 0, 2, "motor axis $(N)",
> {IOC:, 4, "m$(N)", "OMS MAXv", 0, 3, "motor axis $(N)",
> {IOC:, 5, "m$(N)", "OMS MAXv", 0, 4, "motor axis $(N)",
> {IOC:, 6, "m$(N)", "OMS MAXv", 0, 5, "motor axis $(N)",
> {IOC:, 7, "m$(N)", "OMS MAXv", 0, 6, "motor axis $(N)",
> {IOC:, 8, "m$(N)", "OMS MAXv", 0, 7, "motor axis $(N)",
> I'm not sure why I'm not able to communicate with the MAXv controller
> ( maybe it has something to do with the bspExt warnings? ). I hope
> that covers the relevant details. Any help or advice would be greatly
> appreciated. Thanks!
> Regards,
> Jim Eastman
> This e-mail and any attachment(s) are from Pro-Dex, Inc. and may
> contain information that is confidential or privileged. If you are not
> the intended recipient, do not read, copy or distribute the e-mail or
> any attachments. Instead, please notify the sender at the phone number
> indicated above and delete the e-mail and any attachments. Thank you.
This e-mail and any attachment(s) are from Pro-Dex, Inc. and may contain information that is confidential or privileged. If you are not the intended recipient, do not read, copy or distribute the e-mail or any attachments. Instead, please notify the sender at the phone number indicated above and delete the e-mail and any attachments. Thank you.
- Re: Problem with Motor Record on RTEMS on MVME5500 Kate Feng
- Problem with Motor Record on RTEMS on MVME5500 Jim Eastman
<2011>
2025
2026
<2011>
2025
2026
