1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: caSnooper latest version
Date: Mon, 14 Mar 2011 14:45:07 -0700
Ok thanks.
If I find anything within the caSnooper application, I'll submit back as a patch.
Murali
-----Original Message-----
Sent: Monday, March 14, 2011 2:29 PM
To: [email protected]
Cc: Shankar, Murali
Subject: Re: caSnooper latest version
Hi Murali,
On Monday 14 March 2011 15:41:11 Shankar, Murali wrote:
>   We are seeing a couple of issues with caSnooper here at SLAC and I am
> trying to get to the bottom of these.
> 1)      Some network issues have been reported when using caSnooper with
> EPICS R3-14-8-2x. Using  R3-14-10 just for caSnooper in a R3-14-8-2x
> environment seems to be a workaround.
I disagree; there were several changes to the CAS code in between those
releases to fix issues in the CAS.  If you've found that using a newer version
of Base solves some problems then there are no changes that could be made in
the caSnooper application code to fix them.  EPICS is *designed* so that
different versions will inter-operate properly over the network; you shouldn't
hold back the version of Base that one application like this is built against
just because other parts of your system are using a different Base release
(although that does matter when different pieces of code are going to be
linked together into a single executable such as the support modules in an
IOC).
> 2)      These seems to be an issue with the -c  (Check validity of top n
> requests) on Linux. We are working around this using a perl script to
> digest caSnooper output and then caget for the validity check.
> Is version caSnooper2_1_2_1 (10 Aug 2007) the latest? If this is being
> actively maintained, would there be a later version elsewhere? Are there
> any patches to caSnooper2_1_2_1 we are missing?
There have been no commits to CVS since the 2-1-2-1 release that I can see
from the cvsweb view at
  http://www.aps.anl.gov/cgi-bin/epics/cvsweb/extensions/src/caSnooper/
Since Ken Evans retired we've not had to make changes to caSnooper here at APS
— I suspect SLAC is using it more than APS now.  If you guys want to
contribute patches we'd be happy to include them, but other than build issues
on newer OSs I don't think we have the effort to actively work on it any more.
HTH,
- Andrew
An error is only a mistake if you don't learn from it.
When you learn something from it, it becomes a lesson.
caSnooper latest version Shankar, Murali
Re: caSnooper latest version Andrew Johnson
Prev: Re: caSnooper latest version Andrew Johnson
Next: class library header file naming and install conventions Jeff Hill
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
