1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: class library header file naming and install conventions
To: "'Bruce Hill'" <[email protected]>
Cc: "'EPICS core-talk'" <[email protected]>, [email protected]
Date: Wed, 16 Mar 2011 09:48:53 -0600
> By Xxxx are you implying that class names start with upper case?
> EPICS seems to mostly have class names start with lower case and
> use camelCase for compound names, so perhaps the strawman should
> use xxxYyyy as the example class name.
EPICS was following vxWorks convention in the past -
which was to start all names with lowercase, and to capitalize the
start of each word, when changing to a new word. This was a convention
adopted originally only for C code, and both C functions and structures
used this convention.
It's now very common to name all C++ classes (types) starting with a
capital letter. This seems to be very beneficial in our context
because it distinguishes C++ type names from function names nicely.
I have been naming all C++ classes and types beginning with a capital
for several years now.
> I'm not sure why the lib directory is needed.
Others have provided the same comment. It seems that we might
organize subdirectories under $(EPICS_BASE)/src/pdq like this.
option 1: {lib, doc, test, ...} (where lib contains pdq.h,
					Xxxx.cpp, Xxxx.h, Yyyy.cpp. Yyyy.h)
option 2: {pdq.h, Xxxx.cpp, Xxxx.h, Yyyy.cpp. Yyyy.h, doc, test, ...}
I appears that perhaps more folks prefer option 2.
Jeff
______________________________________________________
Jeffrey O. Hill           Email        [email protected]
LANL MS H820              Voice        505 665 1831
Los Alamos NM 87545 USA   FAX          505 665 5107
Message content: TSPA
With sufficient thrust, pigs fly just fine. However, this is
not necessarily a good idea. It is hard to be sure where they
are going to land, and it could be dangerous sitting under them
as they fly overhead. -- RFC 1925
> -----Original Message-----
> From: Bruce Hill [mailto:[email protected]]
> Sent: Tuesday, March 15, 2011 3:03 PM
> To: Jeff Hill
> Cc: 'EPICS core-talk'; [email protected]
> Subject: Re: class library header file naming and install conventions
> Hi Jeff,
> Thanks for putting together a straw-man on this.   I agree this
> is an important topic and I'm glad you're addressing it.
> I generally like what you've proposed, so I'll just add
> a few comments below.
> Regards,
> - Bruce
> On 03/14/2011 04:11 PM, Jeff Hill wrote:
> > All,
> > When designing a C++ class library whose name is pdq it seems that one
> might
> > implement one header file for every exported class, and follow some
> naming
> > rules.
> > Here is a straw-man. Lots of other schemes are possible, and the only
> really
> > bad scheme is to follow no naming convention at all, I suppose.
> > o The C++ namespace is pdq (class lib names must be all lower case
> letters)
> > o The master header file's name is pdq.h
> > o Each exported class named Xxxx has a header file named pdq/Xxxx.h
> EPICS seems
> to mostly have class names start with lower case and use camelCase for
> compound names,
> so perhaps the strawman should use xxxYyyy as the example class name.
> > o The master header file has '#include "pdq/Xxxx.h"' for each exported
> class
> > o The pdq.h is installed to $(EPICS_BASE)/include/pdq.h
> > o The pdq/Xxxx.h are installed to $(EPICS_BASE)/include/pdq/Xxxx.h
> > o The build system appears to implement this type of install now if, in
> the
> > build area, one has something like src/pdq/lib/pdq which contains the
> header
> > files (where they are installed from). Is that what we want? That
> (redundant
> > pdq in the path) could be initially somewhat confusing to the
> uninitiated,
> > and I don?t see any reason to place the header files in a subdirectory
> other
> > than to avoid changing the build system?
> I have no problem with pdq appearing twice in the path,
> but I'm not sure why the lib directory is needed.
> > o The c/c++ files are named src/pdq/lib/Xxxx.cpp
> Ditto here.    Why not:
> src/pdq/xxxYyyy.cpp
> src/pdq/pdq.h
> src/pdq/pdq/xxxYyyy.h
> src/pdq/doc/pdq.html
> src/pdq/doc/pdq/xxxYyyy.html
> > o The documentation master goes in src/pdq/doc/pdq.html
> > o Maybe the class interface documentation goes in
> src/pdq/doc/pdq/Xxxx.html
> > (same concerns about redundant pdq in the path)
> > All comments appreciated.
> > Thanks,
> > Jeff
> Bruce Hill
> Member Technical Staff
> SLAC National Accelerator Lab
> 2575 Sand Hill Road M/S 10
> Menlo Park, CA  94025
class library header file naming and install conventions Jeff Hill
Re: class library header file naming and install conventions Bruce Hill
Prev: Re: EPICS and large CAN systems Andrew Johnson
Next: Re: EPICS and large CAN systems Rolf Keitel
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: class library header file naming and install conventions Bruce Hill
Next: Message logging survey Hall, Robert D.
